Frank Klausz bow saw
Dean Lapinel
>Three questions:
Are the dimensions (specs) for the famous Frank Klausz bow saw available anywhere?
Does he use band saw blades?
is that trick blade available anywhere?
Thanks
Re: Frank Klausz bow saw
Bill Tindall, E.TN
>I studied one in the cabinet shop at Old Salem in NC. It had a very coarse band saw blade, I think 1.5 tpi and about a 1 " blade. They seemed to use it.
>Dean,
Send me an e-mail if you are interested in a blade.
Stephen
Glenn Madsen near San Francisco
>And what if Dean isn't the only one interested in a blade?
Do they take three weeks to hammer out of 1865 vintage iron? ;-)
I bought several chunks of band saw blade last week to make some 'prototypes'. The sharpening shop owner cautioned me on several issues, mostly regarding hook angles, but I have pressed on regardless a very short way so far.
A blade with a recommendation from someone firmly rooted in the hand tool tradition might help a lot...
ThomD
>They look like fine turning blades and are heated and hammered along an angle. Bandsaw blades aren't the best source for bowsaws to start with. In his original article he was talking about making boxes for furniture. So the material was probably softish, and reasonably thick. From that you can extract tooth form and hook angle. Or from your own needs.
I'll let you know
>I've got a call in to Frank. Should hear back tomorrow morning about the bowsaw plans. To answer your other question, Frank makes those trick blades with a propane torch and a couple pairs of pliers. Very quick and easy.
Re: I'll let you know
ThomD
>That does sound easy. Wouldn't have thought it was that easy though. In the drawing I saw the blade was flattened around a corner, Not just spiral twisted. So as the teeth went in for the corner they would fit around the corner. and gradually expose more tooth. If sawing dovetails, there would be a difference between the angles for pins and tails, even various tail angles. Sounds a little too complicated for pliers. I'll be happy if it turns out to be simple.
Dean Lapinel
>Thank you Ellis. This is so typical of you (being a kind gentleman).
Dean
Update and a correction
>Regarding his large bowsaw, Frank says that the blades are available from the sources mentioned in the article in Pop Woodworking. The saw itself is made from 5/4 material. The legs are 16" long and the stretcher is the same length as the blade -- 27" in this case. The turned handle is 6 1/4" overall with a 1/2" diameter tenon that goes through the frame. He uses Italian upholstery twine to tension the blade. You'll have to scale the details from the photos in the article.
Now, a mea culpa. My recollection was incorrect regarding the "trick" blade. It is indeed a 1/4" but Frank didn't make it himself. He only has two of them and has looked high and low for someone who can make them, to no avail. He's tried to get some of our more enterprising manufacturers to make them, but so far no joy. He says the blade is pretty sophisticated, with graduated teeth and a spot at the twist with no teeth. I would imagine that there could be tempering/annealing issues to deal with, too. The upshot is, if you find one of these blades somewhere, snap it up. If you find more than one, give Frank a call and he'll be your friend for life. :)
Re: Update and a correction
Joe Rogers, Northern Virginia
>WRT the trick blades...I was at a live demonstration hosted by Roy Underhill and he had on 'o' those trick blades. The demonstration was impressive but the blade has seen better days and may have died since then. I don't remember if Roy said he had made the blade or not but it had a crack starting at the corner and was gonna go soon.
JR
ThomD
>I think they would be relatively easy to make if one had a quality mechanics vise of about twice normal length. Hmm, that sets me thinking...
I was thinking sheet metal brake
>If the saw blades are tempered springy enough to bend without breaking, the basic bend should be possible with a good sheet metal brake. The brake will make a clean bend, and you can judge 90 degrees pretty accurately. Then I guess it would be a matter of grinding off unwanted teeth.
I used to work at the tin bender's shop around the corner from my house. The man who owned it when I was there is long gone, but I've stopped around and told a few lies from time to time with the current owners - maybe if I ever get enough round tuits together, I should stop by and see if they'll let me experiment with an otherwise funked-out blade that I picked up at a yard sale.
Probably be ages before I could get that particular round tuit, though. Who's got easy access to a brake? Rob Brophy? Cooper Suter?
Re: I was thinking sheet metal brake
ThomD
>My best guess is that won't work, unless the saw metal is really soft or the teeth get filed in afterwards and tempered. No teeth are removed with this kind of blade, they just wrap around a corner as if laid diagonally over and angle. Brakes's main problem would be getting hold of such a narrow piece and the material's hardness. Still it would be cool to try everything.
Re: Could be wrong
ThomD
>On the other hand. I was looking at a brake today at the machine showroom, and it looked plausible. It is still going to be a problem if the material is hard enough. I am thinking of sneaking back in to see. That said, when bent it will be horribly out of line and will need some heat to relax it.
