Re: Workbech finish
ThomD
>I would second some kind of drying oil. You can mix tung and BLO, and add enough drier to it to get it to dry ovenight. That can be very beautiful. Another good finish is Watco, if you have a local supplier.
If you want something with a little build do the Blo, tung, varathane in equal amounts, a very good finish for looks.
I don't think once you go to hardwood, put on a finish, that adding wax will hurt much. There is something to be said for a raw pine bench, something with some stick to it. But finished maple is going to be slipery, at least with wax you will not have the glue blobs adhering.
From a finishing perspective it is hard to get something on light maple that doesn't darken and yellow it. That is where you get into stuff like white shelac, and restorers wax. You could do that on a bench but at the end of the day maple gets nailed with all kinds of colours, just look at violins. If you don't want it to be yellow, the solution there is to go amber, which many finishes naturally are. I have a little bottle of amber instrument dye that I add to stuff like valspar diamond finish that dries with a blue tint. Just the minimum to edge the finish to an appealing tone. I have pieces I sprayed that look like they were oiled rather than frosted with sugar. The spray won't go in and get the deep colours up, but one doesn't always want that either.
