Some chisel handles
Some chisel handles
Some chisel handles
Dominic in Buck's County PA
>Hi Gang,
Over the past couple months I accumulated some nice socket chisels from Ebay and Flea Markets. I had some 720s, some Ward Masters, a Samson Hrdw, a Union, and a 3/4" Witherby (which was a real surprise since I got it for $1)
Only a couple of them had handles that were usable. So I decided to pick out the one handle that I liked the most, and pattern new handles for the rest of the chisels from it. The handle that felt the best in my hand came from a Wards Masters Chisel.
So I rooted through my wood pile and found some bubinga that was given to me by my good friend Ron Sardo.
Here is an "in process shot"
Photobucket
And here is two of the completed handles.
Photobucket
Photobucket
The 6th handle in from the right is Lyptus. This is the same wood I got on my visit to Bally Block. It looked so nice that I decided to turn one handle from it. It wasn't as dense as the bubinga, so it turned a lot easier. It's heavier than beech. It was almost like a dense kind of mahogany. It took an edge well and sanded easily.
(3) of the handles were in perfect shape. I may or may not replace them. They feel good as they are.
Now I just need to apply a finish. I'm thinking some like of wipe on lacquer. Then it's on to flattening the backs and sharpening.
See ya around,
Dominic
Re: Some chisel handles
Nice
>chisels can be really addictive. I've given away some of the less impressive ones I've picked up to the local Restore (at about 50 cents each at garage sales, it's easy to come home with some that later don't look quite so nice), and I still have a drawer full more than I can figure out how to use. The subtly different shapes are just so interesting...
Wiley Horne-- So. Calif.
>That's a satisfying picture, Dominic. As Bill said, the little differences from chisel to chisel give each one its own identity, and pretty soon you know the 5/16" from the 3/8", each one by its handle without looking at the blades.
Show 'em again after the finish goes on!
Wiley
taper fitting
Bill Tindall, E.TN
>How do you achieve a good fit for the tapered part that goes into the socket?
I would oil the handles. Indeed lacquer would look better but oil will feel better.
Re: Nice
>Thanks Bill! The shape of the handles sort of evolved as I was turning them. I started with the thinnest chisels and moved to the wider ones. I can see the difference as I got more comfortable with turning just the shape I wanted.
At one point I was going to burn lines into each on that corresponded to the number of "1/8s". You know, and 1/8" chisel would have one line, a 1/4" would have two, and a 3/8" would have three. But that went by the way side as soon as I completed the first one! :>)
>Thanks Wiley!
Re: taper fitting
>Hi Bill,
Each of the handles was custom fitted to a chisel. I've rough turn the blank to a cylinder then I'd mark off the point where the taper would start and end using a parting tool and a set of calipers. I'd turn the taper to fit the socket and get it to fit before going any further. THEN I'd turn the rest of the handle.
And as far as an oil finish, what would you recommend? BLO?
See ya around,
Dominic
Clever idea...
>the graduated burn lines on the chisel, did you think of that?
I would go with BLO for a finish, looks good, feels good and is easy to renew.
Stephen
Re: taper fitting
ThomD
>If I don't know what the taper is I take a known dimension ruler, or drill bit and insert it into the socket and not the depth. Then i measure the mouth. With that I have the taper. I turn the taper a little short of max depth. Then I super dry the tenon, pound it home and let it swell into position.
Thanks!
>Like that idea, eh? It just sort of "happened" while I was working one day. I was thinking of away to easily identify my chisels without having to pick up each one every time, or to avoid color coding (which works really well, but I think looks awful)
Its a variation on an old trick from my years as a "CADD guy". You see, AutoCad used to store scale factors for drawings in "1/4s" so when you drew a drawing and wanted it to appear at a scale of 1"=1'-0", you had to scale the text up by a global factor of 12. After a while you knew by the global scale factor what the "real world" scale was.
Indeed, a clever idea, until...
Dan Moening
>...you get chisels in metric sizes!
Hmmm, where's my 16mm ? 1,2,3,4,5... :-)
When I first saw the lines on the handles I thought that might be what you were up to. But then recognized that those with 3 lines were of different sizes.
Still, I think it might be an idea worth pursuing.
Oh, and nice work on the handles. Very satisfying isn't it?
I've always felt that a couple coats of shellac, followed by a steel wool buffing with wax, made tool handles feel just right.
NickTuzzolino
>Dom: What do you do in your spare time? Mamma mia, thatsa a busy boy!! :)
Re: thankyou
ThomD
>I should have said "note" the depth. Glad that helps. My dad had some nice socketed chisels and they always had the handles coming out. Done the right way the fit is pretty much permanent.
Good looking handles you got there Dom!
Scott Burr in Ben Lomond, CA
>I think you need to make them all look alike. Time to turn 3 more...;^)
Completed chisel handles
>Here's a photo of the handles with several coats of BLO applied. I allowed the finish to dry over a couple days and then buffed them with my Beall Buffing system (once a wood turner, ALWAYS a wood turner!). I'm really happy with the results and just need to sharpen a couple more of them and I'll have a complete set all ready to go.
Photobucket
See ya around,
Dominic
Nice! While looking at the handles...
>It almost seems like the grooves tell the size of the chisel to me. Then after going left to right I figured out it wasn't so. Pretty cool idea IMHO (yes, my invention).
They look really good Dom!
Yeah,...right
>Scott,
You might want to read my response to "Nice". I started out making the grooves tell me the chisel size in "1/8s". One line meant 1/8", 2 lines meant 1/4" etc. Somehow along the line I mixed a couple of them up and said, "The heck with it!". Still,....my idea. I said it first!
DOH!...
>I stand corrected!
8^)
Chisel Handle profile drawing
>Hi Gang,
Back when I showed off my new Chisel handles a member of another forum asked for dimensions so he could turn his own. I decided that I could do better than just scanning the rough sketch I used. So I drew them up in Solid Edge
Here is the drawing
Photobucket
And here's a rendering of the model I made (just because I couldn't leave well enough alone!) :>)
Photobucket
Notice I didn't give dimensions for the socket portion. This varied from chisel to chisel and needed to be custom fit each time. My process was to rough out the blank to a cylinder. Then use the dimensions on the drawing and mark off the high and low points with a pencil.
At that point I get a parting tool, turn down at the marks for the socket only, and form grooves to the correct diameter I measure off the socket of the chisel. After screwing up several sockets (and thus ruining the handle) I decided that I would turn the socket first and get the hard part out of the way! After you get the rough size of the tapered socket done, it's a simple matter of turn, take off lathe and see how it fits, back on lathe take a bit more off, etc, etc. Once the socket is a perfect fit, I go and form the rest of the handle.
That's pretty much it.
See ya around,
Dominic
Thanks Dom!
Re: Chisel Handle profile drawing
MikeW
>Hey Dom--I knew I liked the handles you made...
Notice the screwdriver in the upper part of the picture I rehandled a few years ago:
Look familiar? Very comfy shape!
But I gotta say, your handles sure are better looking than my non-descrypt mystery wood I used for the driver.
Take care, Mike
Thanks Mike
>Thanks Mike. I like your screw diver handle! :>)
At first I was going to turn handles like you see on AI chisels. I'm glad I didn't. These fit my hand really well.
BTW, used the small tenon saw again last night. I still giggle like a little kid when I feel/see how good it works. If you think that's funny, you should see the looks my wife give me when she catches me laughing like that! :>)
Later,
Dominic
