Tailed solution for flattening a butcher block?
Denis Ch�nard, Orl�ans, Ont.
>I've built an end grain butcher top for a table that I'm working on. Normally I'd get the planes out and flatten the thing, unfortunately I have a medical condition that precludes me from doing so.
My problem is that I have three hernias, two in the groin area and one under the belly button. And these get really painful after doing any activity that involves use of force in a lateral motion, like shoveling or planing. Even walking for more than a couple minutes gets painful.
I'm on a waiting list to get these fixed, but I have a deadline on this project that occurs before my expected date under the knife.
So I'm looking for alternatives, and in this case a tailed solution seems to be the way to go. All I can think of right now is some kind of sled arrangement to use a (tailed) router with, however I'd like to hear of any other possible approach. The important issue here is to minimize the strain on my hernias. I think I can finish plane the top, but getting there is where the problem lies. I have to take off between 1/16" and 1/8" off the top surface.
Any suggestion welcome...
Thnx,
DC
Re: Tailed solution for flattening a butcher block?
MikeW
>Hi Denis--know of a close cabinet maker with a wide belt sander? Absolutely the easiest.
However, the sled and router will work. If it is over sized, I have well wetted the surface of some and put them through my elec' lunchbox planer as well. Issue is with the planer is cutting off any trailing edge breakage. Chamfering the trailing edges ever so slightly minimizes the edge breakout. I have used mineral spirits to wet with, but on the last couple I wetted the surface well with the oil I use on the things anyway. In my case usually Walnut oil.
Take care, Mike
"RJ" Whelan
>Dennis ... if you can find a cabinet shop with a 36" belt sander (that's willing to rent time on the machine - I do this on a regular basis with dining table tops and it's never cost me more than a case of beer) that's definitely the way to go.
Just be sure to dust, vac and tack the whole thing before using your planes as grit from the belt(s) can become imbedded in the end grain - DAMHIKT.
Good luck with the butcher block and the surgery ... rj
what I do on butcher blocks
Bill Tindall, E.TN
>I agree that a sander is the way to go for removing this tiny amount. But, I regularly plane end-grained cutting boards. I glue a waste piece on the trailing edge to absorb the chip-out and then cut it off after planing to thickness. Following planing I belt sand. This is the only case where I still use a belt sander. Removing end grain material is waaay sloooow. The belt sander, even with a relatively coarse grit, leaves a glass smooth surface.
A Makita hand held tailed planer?
Pam Niedermayer, Austin, TX
Re: A Makita hand held tailed planer?
ThomD
>I have a makita, and I wouldn't think it has the guts to trim end grain hardwood, but then I have never had the guts to try it. I would do the sled and router thing with about a 1" bit if possible. I think the correct disc sander would also work, but it takes a light touch and most people don't own the right kind. A belt sander would work but can be about the same amount of work as planing.
What do you use it for?
Re: What do you use it for?
ThomD
>I bought it in the 80s and used it until the blades got dull. That wouldn't normally stop me, but I haven't had a sufficient reason to change them. They are handy for shaping things and getting out material. Also handy for taking to things too large to take to a jointer or planer. I think the beam width ones would at least save enough work to be worth the effort themselves. It's great if the job is out of doors because the indoors clean-up isn't worth it.
I think one thing they are good for is stuff one would do with a scrub or jack plane, or drawknife, but the wood is too crap to allow it.
They are also useful in boat building which runs to big enough jobs that playing around may not get the job done. Another production thing would be contract door hanging. Hang and fit the door install the locks in like 10 min each. No time to fritz around with hand planes, in fact these days little time to fritz around with anything other than pre-hungs. I do the boats but not the doors.
It's somewhat my dichotomy of production vs. a hobby. If someone wants a tapered flag pole and you would just as soon not, but you sorta have to, then out come the nasty noisy things.
Thanks, Thom.
