Something to mull over
Wiley Horne-- So. Calif.
>Hi Dominic,
What Thom said on the lamination question.
Do you have an LV twin screw, or something else? Either way, there is a bit of a trap one can fall into using really thick wood for jaws. Especially the rear jaw. The thicker the rear jaw, the greater the distance between the main screw nut and the front jaw. Which means the front jaw is cantilevered further from its support (the screw nut) than it needs to be. Which in turn makes the front jaw more likely to sag. Unless you mortise the nut into the rear jaw, in order to reduce the cantilever distance.
Also, the thicker the front jaw, the heavier the load out on the end of the cantilever, which also contributes to sag.
So. I would suggest either reducing the thickness of the jaws, down to 2" or a bit more, or else mortising the supporting nut well into the rear jaw, for the reasons given above.
I mention this stuff because it's a bit counterintuitive. It seems like the studlier the jaws, the stronger the vise. However, when you think about the leverage in the system you're building, you may conclude that 2" jaws will lead to a stronger vise than 3" jaws.
Wiley
