Re: The numbers
ThomD
>"1.) How thick does the seat need to be? 2"?"
If you carry it around, lighter is better, Keep in mind the surface you will place it on if it is really slick, you need more socket joint at the bench than otherwise. Check windsor chairs for reference. Species and quality make a difference, check split resistance. As long as it doesn't flex when you sit on it you are fine. Self-testing should determine more than someone elses number.
2.) How long should the bench be for the horse to be functional?
I depends on the design. Some of them have more out front than others. The boggs is very short overall, because both the seat and the bench are compact. You can rest the rear on something and play with it until you are sure relative to your height. Then attach the legs.
3.) How wide should the saddle area be? Is it dependent on how wide I am
Sorta. Your sit bones do the sitting, the rest of width is based on your "overhang" The sit bones are rather narrowly placed. Wider isn't always a more comfortable design because you are moving, getting on and off, and possible carrying it around.
Stiffness of the plank is proportional to width, and the cube of thickness, so these can be altered from known designs to suit your use.
Your choice should probably be based on the kind of work you do. A big part of that is the length of pieces.
I have two, one is a dumbhead from Drew's chair book, which has an excellent design. Tamarack and red oak. The other is a maple version of the Boggs chair from about 10 years ago when it appeared in FWW.
