In Spite of all of the good information...
>that I was provided and following directions to the letter I still managed to break something.
Well I put that big moment on the steel and heard it happen. The socket came loose at its weld.
All is not lost as it was much easier to fit up a handle. When I do this again I will sacrifice the handle (I think).
Stephen
Re: In Spite of all of the good information...
That's what is supposed to happen, Stephen,
Wiley Horne-- So. Calif.
>it isn't a socket. That is a tapered ferrule above the bolster. You did it exactly right.
Wiley
wilbur
>Actually, that's how the chisel is put together. The "socket" is a ferrule that fits to that part of the chisel. I have to admit, though, I don't know off the top of my head if the ferrule is welded to the main blade or not.
Now you tell me!.
>I could barely make out the line which I thought was a weld line, I had seen another post elsewhere. So I don't feel bad now and am on my way to having a Western style laid steel chisel.
The handle doesn't have any linseed oil on it yet, it is actually quite curly.
Thanks for all your help.
Stephen
Re: Now you tell me!.
Dean J in MN
>You're most of the way to a Western tool. Now if it weren't so darn thick we'd have something.
-Dean
ThomD
>That is why it can be difficult to get back together, because they grind that junction, or so it appears, and it doesn't always settle back in there.
The blade or the handle?
>I think the handle might be a bit thick, but I like a big end. As for the blade, the top is soft enough to cut with a file, so my very slow hand grinder could reduce its thickness, not a bad idea. I could also remove the non-Western lettering.
If sombody offered a rough blank, I would buy some.
Stephen
Re: The blade or the handle?
Dean J in MN
>I like the handle, I was speaking to the fat blade. Let me know when you have it ~1/16" at the start of the bevel.
-Dean
Tony Z.
>Now exactly what is it you are after (said tongue in cheek remembering your post when you first bought the chisel for the laminated steel).
T.Z.
