New Dovetail Vise Idea *LINK*
Hank Knight
>A couple of years ago, I posted about the dovetial vise I built into my bench. I imbedded several 1/2" X 13 machinists "T" nuts in my dog hole strip and use threaded studs with speed handles and a hardwood "jaw" to clamp flat stock to the face of my bench.
The idea prompted a lot of nice comments. The problem with the design is that it was hard to retrofit an existing bench with the heavy threaded inserts needed for a vise. Lee valley has solvesd that problem with their new "Bench Anchor."
Their catalog explains how it works it better than I can (see link below).
With the Bench anchor, all you need is two 3/4" holes in the front face of your bench top, two 1/2 X 13 threaded studs, two aluminum speed handles and a hardwood jaw. I've tried it with the Bench anchors and it works great. Easy peasy. Plus the Bench anchors can be removed by simply unscrewing the internal screw and pulling them out. I've used my dovetail vise a lot. It's perfect for sawing dovetails, for marking the second pins or tails board (depending on whether you're a "pins first" or a "tails first" person) and it's handy for some assembly operations too. Now, with this great new Lee Valley product, you can add one to your bench at any time.
