OT - plumbing miracles
>Our house has, over the years, amazed me more than once, with "solutions" by past owners that defy probability, gravity, and physics.
I spent today reworking the plumbing line that serves one outside spigot. Some previous owner had run black plastic flexible tubing, with walls only slightly thicker than the stuff for drip irrigation systems, from the galvanized plumbing system to the spigot, a run of about 20 feet. I've been aware of it, with fingers crossed for luck, for years, but there's always been SOMEthing else to do. We get freezes, with lows down into the 20s, and the crawl space is vented and uninsulated - somehow, the pipe has not split or leaked.
Now, as I insulate under the floor, I had to act, because the handle for the cutoff valve at the head of the run was sticking up into the area to be insulated (I think I added the cutoff valve soon after we moved in, when I didn't feel I had time/money to rework the whole thing because I thought then that I would have to go to galvanized pipe, which would have been a royal hassle, as the pipe run goes down, across, and up to avoid framing members).
So part of today was taken up with replacing the shutoff valve (recommendation: don't use gate valves in locations that you don't open/shut regularly) and running PVC to the spigot, adding a stub in case I get around to adding irrigation valves on that side of the house. 35+ years is long enough to depend on the homeowner's fairy; glad to have done this repair, finally.
Happened to stop at a cleanup from a garage sale, as I returned from the first hardware store visit - mid-sized clamp-on "machinist's" vise, screw-on file handle, Stanley saw set that I'll be posting questions about soon, and a little palm-handle Millers Falls gouge, $3 the lot. So not a bad day...
