What I had in mind...
>was to buy a Japanese laminated chisel, which I did and to alter it to 'look' like a Western Chisel. No really Derek. I know it won't look exactly like the old laid steel chisels, but it is a laid steel chisel and that is what I want!
The photograph below is just as I got it, a before picture if you will. I put it to the coarse stones this morning and it was a lot of work and I am not done yet, but I only spend a half an hour. The flat behind the tip is over a 1/4" long but I am working the entire underside, just not all at once. I also sharpened it and did some work on a curly maple replacement handle.
Now I just need to figure out how to remove the handle, if possible without having to resort to splitting it off, any suggestions?
It appears that there is plenty of steel on this one and judging from a picture that Wilbur put up of one of his chisels that has been sharpened down to next to nothing and still has steel, so I am not worried.
As for re-hardening, it doesn't look like this needs it as the steel is very hard, however the backing can easily be cut with a file.
If it is possible to get something similar to the old Western laid steel chisels by modifying a Japanese chisel then I think it would be a good exercise for those wanting original style tools.
I also think Western (Modern) tool makers to consider offering a line of traditional laid steel chisels and gouges, I would pay for real tools.
Stephen
