Re: a question about cutting edges
ThomD
>I don't think there is much magic at play here. If you have planed oak, their brown oak being dark in colour but otherwise a bit like white oak, you don't get a perfect shaving, there are parts that fall out and so forth. Often even a little dust, particularly with our red oak. Pine on the other hand can finished to such a high polish off a plane that you can read the lightbulb in an overhead fixture when looking at the surface of the the pine. Pine shavings will hold together down into the tens. That kind of finish pays off with pine, which it can be argued for certain used doesn't even need additional finish, while Oak will never get that good, and one can proceed directly to the finishing process. It's not that the surface on oak wouln't be better with a great plane, or turning tool, it's that the result after finishing is possibly not an improved surface.
The same thig applies with sanding. There are some materials and finish combination that can be sanded to 150 and coated, while others like 8000 grit. Depends one whether the surface is finished, and even then, what happens when the finish goes on. Some metal surfaces need bondo, and some woods need filler.
