magnifier for saw sharpening
John_in_Az
>Hello All - At my advanced age I'm developing a great interest in working with hand tools. My concern for now is sharpening hand saws, specifically dovetail and tenon saws with 12-16 ppi. My old eyes just cannot see well enough without magnification. My question is, what would work best, magifier goggles with a focused light mounted on them, or a bench mounted lighted magnifier. I'm thinking the head mounted lenses would be more convenient but want to find some of your experiences before I spend the bucks. They're not cheap for good ones. Thanks, John
Re: magnifier for saw sharpening
Marv....... Northern California Lake Co.
>Hi John,
I use the head mounted type that you can get different lenses with different magnification. Each lense is numbered to indicate the magnification. I'm up to a number 5. I also wear prescription glasses, so that will play a part as to determining what will work best for you. For lighting I use a bench mounted flex arm type. I found that a magnifier that is part of the lamp gets in my way, but a lot of people prefer them.
Marv
ThomD
>Optiviser.
John_in_Az
>Thanks for the responses. Marv I think you reinforced my leaning to the head mount magnifier. I had one of the lighted bench mounted magnifiers before that I used for other jobs and not woodworking (it finally broke). It seemed to be difficult to maintain focus and position of the lense and still move around enough to get a job done. Head mount it will be. John
Ray Gardiner
>Hi John,
I favour the head mounted, over the bench mounted, from some angles the bench mounted magifier distorts the perspective, and judging angles is harder. I have an optivisor, and a cheap copy, making it comfortable to wear is important I feel. I think the cheap copy works just as well as the real deal.
As a side note, good lighting is as much of a factor as magnification, you have to see those little tooth points clearly.
Regards Ray
