Have a question? Ask Woody!
pit saws
pit saws
pit saws
mike muzzarelli
>Does anyone have any idea on what the saw plate thickness was? Also how mant tpi? have a crazy idea to maybe build one.
Re: pit saws
Re: pit saws
Dean J in MN
>Open Pit saw or framed pit saw?
Holtzapffel lists as such:
Open Pit saw:
Length of Blade: 6 - 8 Feet
Width at wide end: 9 - 12 inches
Width at narrow end: 3 1/2 - 5 inches
Space of tooth: 5/8 to 1 inch. (This is space between points)
Gage of Metal: 12 - 16 (Birmingham gage) (.109" - .065")
Frame Pit saw:
Length of Blade: 4 - 6 Feet
Width at wide end: 7 - 11 inches
Width at narrow end: 3 - 4 1/2 inches
Space of tooth: 1/2 to 3/4 inch. (This is space between points)
Gage of Metal: 15 - 18 (Birmingham gage) (.072" - .049")
Re: pit saws
Don't know but . . .
steve mackay
>seen re-creations of the operation and it looked brutal.
Re: pit saws
Re: pit saws
MikeW
>Just as additional info...
Smith's Key lists pit saws (open or framed) down to 4' in length. Toothing should be appropriate for the mean diameter of logs to cut.
I think Mr. H's thickness is off at the thin end a bit for both the pit and framed saws, but mostly the framed. Some English pit saw examples from the early 1800s are as thin as the high 50 thou.
I think the framed version can support thinner than Mr. H lists if the frame is built so that sufficient tension exists. Correspondingly, a wider blade should be used the thinner the steel.
Take care, Mike
Re: pit saws
Re: pit saws
Warren in Lancaster, PA
>Mike, if you are serious about making a pit saw you should definitely look at and measure old examples. I haven't used one for a decade or so but as I recall the gullets are rounded, making a kind hook tooth with the sharpening done on the back side of the tooth with a flat file. I also think the teeth were graduated on at least one of the saws I have used. Some saws with triangular gullets are displayed as pit saws, but I think they are really ice saws.
Pit sawing is a little more tiring than jogging. However, it makes a big difference what kind of partner you have. A guy who is a steady and smooth worker is a lot easier on you than someone whose motions are jerky or of uneven pace.
Re: pit saws
I hope
Bill Houghton, Sebastopol, CA------WebKitFormBound
>you've got a friend who likes being covered in sawdust. From what I've read, the pitman* got pretty filthy.
*Dictionary.com doesn't help on this. I've assumed for years that a "pitman" in the sense of connecting rod is a reference to the "pitman" standing at the bottom of the pit, pulling down on the saw, wondering when lunchtime was. Anyone know?
Re: pit saws
Sawdust
>I have done the bottom more than the top. The saw is in front of your face with the teeth pointing away and the saw angles away as it goes up. The sawdust doesn't come near you unless there is a strong breeze.
Eric Sloane wrote in the sixties that the man on the bottom was showered with dust and wore a large hat. However, his own illustration shows how unlikely this is. I doubt he was speaking from experience.
Re: pit saws
"whip" or "frame" ?
paul womack
Re: pit saws
Re: "whip" or "frame" ?
mike muzzarelli
>I am not sure which type I want to make. By the way what should I look for as regards to saw plate, type of steel etc.
Re: pit saws
Excellent question.
Chuck Nickerson
>I'm also hoping to make pit saws, at least one of each.
Re: pit saws
Re: Sawdust *LINK*
>I had a slightly different experience when I used a pit saw. It is a little too long to discuss here so I put a post on my blog.
Stephen
Full Chisel Blog
Re: pit saws
Re: pit saws
Adam Cherubini
>I looked at 2 saws in use in Williamsburg. One was .063, the other was .090. Guess which one the preferred? Trick question. They preferred the one with more rake!
Adam
