Sharpening a chainsaw file
Dale Lenz
>Read somewhere by soaking a file in acid, maybe Muradic(sp), would etch the file metal. Wondering if this would work for a chainsaw file, they don't seem to last very long.
TIA
Dale
Dale Lenz
TIA
Dale
Re: Sharpening a chainsaw file
Dean J in MN
>Citric Acid.
MikeW can chime in with all the details. I used a bunch of Kool-Aid packets from the pantry to give it a try. It works quite well. I think I used 10 packs in about 32 oz of water. Something like that anyway. Be warned, doing this will stain your fingers an odd color for a few days! :) Pick up some citric acid from a wine/homebrew shop.
My rasps and files have never been better! I can't see why a chainsaw file wouldn't respond the same. Triangle saw files don't seem to be recoverable, once the edge (junction of the two faces) is shot you can't recover the file.
-Dean
Re: Thanks, Dean.
Dale Lenz
e-bay
Jim in Burlington On
>You can buy the files off of e-bay for about a buck each. I've had good luck with old stock files. Made in Germany files also seem to hold up.
Re: e-bay
Dale Stansbery
>I don't know how much filing you do, but the files I use generally cost about a $1.25 at my local old fashioned hardware. I think I get enough use out of them that at the price, they'd not be worth messing with. I'm actually using a twin pack of 5/32 McCullough files for my small saw right now, but I don't recall what they cost, but not much. They seem to be lasting pretty well. I also try not to run into the ground often so I get a lot of miles on a sharpening :-).
MikeW
>Oops, sorry for being late to the party...
Dale, like a triangular saw file, chainsaw files can get too worn out fairly easy. But ya know what? It doesn't hurt to try.
Anything around your house that is powdered and citrus-based will work for a trial. Most powdered lemonade, or whatever, drinks are basically the same citric acid you'll buy from a brew shop. More expensive, yes, but if you have the stuff in the cupboard, give it a shot.
The ratio of acid/water isn't too important. Other than a strong mixture acts faster than a weak one. Be sure to clean the black gunk off the surface once or twice that will develop. If the file(s) are not too far gone, you will at some point feel the file(s) get actually pretty sharp as you rinse them clean periodically.
Take care, Mike
ThomD
>OK, I finally came across a post I had some info on this in:
Couple of non-toxic methods here as well as...
http://www.practicalmachinist.com/vb/showthread.php?t=115178&highlight=file+sharpening
Post 49 here is pretty interesting:
http://www.practicalmachinist.com/vb/showthread.php?t=96287&highlight=file+sharpening&page=3
