I'm a wretched prodigal backslidin' reprobate
David Barnett - SW Florida
>But sincerely, thank you for asking, Scott.
I've been busy, and not just for myself. Although I've done some woodworking, most has relied heavily on considerable electron attrition where sheet goods were often involved. Handtooling (mostly with files and scrapers) was limited to detailing, fitting joints and veneering. Thick aluminum plate was bandsawn and attached with high-tech machine screws and modern adhesives. Design elements are stacked plywood edges rather than faces, and the casework has no handtool finesses.
Luminaires are hybrids of thick aluminum, MDF with quarter-sawn BRW veneer, non-orange non-shellac synthetic resin mineral (mica) shades were formed with a heatgun from large sheets of the stuff. Nothing organic. No curves, streamlining and somewhat retro. Where solid woods ARE used, they're usually bleached, or bleached-dyed-bleached again. While incandescent bulbs will initially be used, compound LED bulbs will replace them. Newer shadeless lamps will employ cast glass (my own PDV) and other somewhat indy materials.
I've been absorbed in audio isolation tactics and folded transmission line speaker designs employing very small full-range drivers. Sheet goods, tablesawing and veneering, of course. Simple and cheap electronics have produced a very fast, very musical and lively integrated stereo amplifier (a 'gainclone') with external power supply. I've already started a second one. I don't get out much.
There's more, but I'll stop with these heresies for now. Obviously, I'm going through a phase. Be patient. You never know when I'll return to the fold.
