3 Legged Stool Plans?
David Miller from Iowa
>Anyone have a design for a 3 legged stool? Preferably one that doesn't need turning.
Thanks, David
Thanks, David
Re: 3 Legged Stool Plans?
James Watriss
>How elaborate are you talking here? You can take a power drill with a matched set of Lee Valley (or other) tenon cutter and brad point bit, and make a pretty rustic looking milking stool in very little time at all. It won't be very elevated, or sophisticated, but it'll be functional.
The range after that as I see it moves roughly along these basic ideas...
-shorter three legged stool with carved seat, and wedged round through tenons
-taller, saddle style seat, longer legs, and stretchers.
-Something taller, with stretchers, smoothly shaped, tapered legs, and possibly a back. Maybe through tenoned, maybe not. Sculpted, joined in different ways...
Three legged stool is a very non-specific description.
Sorry if I sound like a smart ass.
ThomD
>The obvious example there is if you want something that doesn't require turning, isn't Windsorish, would be Tage Frid's stool. He gives the plan in his book which is probably available to most libraries, and possibly still in print.
http://www.highlandwoodworking.com/woodnews/tage_frid.htm
How many stools include a dovetail joint? I used tapered tenons on mine.
Greg B�tit Crown Point NY
>Here's a design that hails from the dairy farm, prior to the milking parlor era. It was hanging up in the horse/cow shed when I moved into this place. The strap is to hang the stool on to your belt. The handle is to pull it up between your legs as you sit.
Well when I milked as a high school part time helper, I had a metal 4 legged stool with no belt or handle that I had to drag around the barn along with all the milking parephenalia. Afterwards I remarked to a friend (a Vermont farmer who raised sheep) that I thought the traditional design was a great idea, and would have been a real help when I milked. He replied: "How much respect can you have for a man who straps a stool on his belt?"
greg
