Cleaning mortice botoms
>I have been planning to get a Japanese shoji (bottom scraping chisel) for some time. Each time I am about to pull the trigger, I say to myself that it is something one could easily make from a hex key. Of course, I then forget all about it .. until the next time.
Incidentally, were swan neck chisels - the Western equivalent of the shoji - made in sizes below 3/8"? I have never see a 1/4".
Anyway, today I need to clean a couple of shallow 1/4" mortices, ones that would be viewed rather than hidden under a tenon. They were too short for the standard router plane blade.
Then I remembered a blade I had made a couple of years ago. This one scrapes rather than cuts. Another hex key wonder! :)
The router plane was used in bullnose format here as I lacked room.
It works very well for this task.
Re: Cleaning mortice botoms
Bob Demers
>Derek
LV sell both a 3/8 and a 1/4 in swan neck chisel.
I like your idea of hex key, must try that soon
Regards from snow country
Bob
wilbur
>If by "swan neck chisel", you mean the chisel marked with the red triangle in the photo, which is the chisel that is used to clean up the bottom of mortises in shoji, Hida Tool has them in 4.5 mm and 6 mm widths.
The Henry Taylor website lists western style swan neck chisels in 1/4" and 5/16" widths.
Joel also carries western style swan neck chisels by Two Cherries in a 6 mm size.
Re: Cleaning mortice bottoms
>Hi Wilbur
I wasn't after buying a shoji - they look so simple that I plan to make my own. But that was the issue. I keep planning to do so and keep procrastinating, that I never have something to use when one is needed. :) Hence this router plane blade.
Anyway, a shoji could not have flattened/smoothed the mortice well enough for the purpose for which it was needed.
wilbur
>Just to clarify, the name of this particular Japanese chisel is a bottom clean up chisel, or sokosarainomi (底渫鑿). A shoji is the screen that you make with these tools.
Why?...
Scott Burr in Ben Lomond, CA
>I've never seen the need to get a "spotless" bottom of a mortise. As long as it bottoms out, that good enough for me. Yes' this means that it will be a tad deeper than needed, but so what.
It's not like the end grain to straight grain joint is going to add any strength.
Re: Why?...
>Why Scott? Because the bottoms of these small mortices will be seen when the tools in question are removed (a dovetail marker and a saddle square).
The fun part of my workshop rebuild. :)
Ah Ha!
>Now I get it! Nice looking gauge holder you got going there.
Do I smell a tool cabinet in progress?
Nice driveby there, Derek
>Those trammel points are sure interesting. Make my rusty old Stanleys look like they're wearing jeans with holes in the knees.
The trammels ...
>Hi Bill
Trammels are so useful when scribing large arcs or transfering measurements. This is the only set I have, and it took a few years to find ones I really liked. They are a comfortable size and one has a pencil holder. They are nameless, so I suspect that they are a copy of a Preston set that I have seen that was identical. Perhaps someone here can help with the identification. The bar I made from She-oak and brass.
Re: Why?...
Charles
>Whoa now, that would imply that they will actually be used for something.
Come on, fess up, how often will that really be? :-)
Why not?
>Hi Charles
They all get used, especially the little Bridge City saddle square. The dovetail gauge is one I made at 1:7 as this is the ratio I like best.
With regard the squares, I must admit that I am just as happy with an old Starret 6" double square. The Colen Clentons look nice,tho':) .. and the mitre square was one he traded with me for one of my marking knife sets (I came out best here!).
The square that I have used the most here is the little 4" one. It is made by Crown, as cheap as chips, and a really handy size. I've had this one for several years.
Pretty tools - something nice to admire on the workshop wall, as well as use.
Re: Why not?
Pam Niedermayer, Austin, TX
>Indeed, why not? Some people just hate seeing other people have fun. :)
Pam
