Re: Another holdfast querry
Adam Cherubini
>I have a few preferences.
The first hole to bore places the holdfasts shank in alignment with the business side of the planing stop. So if you are working a wide board for a carcass side you can place a batten across the planing stop and the holdfast's shank and the batten will be square with the long edge of the bench. I place this hold fast so that it's foot can sit on a 1"x12" when the 1x12" is engaged against the planing stop.
Then I think it makes sense to place a few holes every two or three feet from there. I stagger them to be in line with the first stop, and then closer to the front edge of the bench such that the shank will contact a 1x12.
If you do this, there are a ton of tricks you can employ to hold all sorts of odd stock sizes by using cheap pine 1x12's from your local home center. I'm not just thinking of planing 1x12's but using them as make shift sticking boards.
Most benches are pretty good at holding long boards with square edges. I find holding short wide boards, boards with non square ends, or thin or narrow stock is the real trick. End vises generally aren't good for any of this stuff.
Not sure how you guys bore holes in your benches. I use ship augers or fine lead brace augers.
Good luck,
Adam
