ADVERTISE HERE - FREE TRIAL
Cleaning hand saws
Cleaning hand saws
Cleaning hand saws
Paul Londo
>Does anyone have a sure-fire way to clean hand saws , specificaly to bring out the imprint on the blade. I just picked up a Diston #7 crosscut that I can read about 1/2 the imprint and was wondering if there was a way to bring it out more.
Re: Cleaning hand saws
Sure fire is a pretty big term..
David Miller from Iowa
>I usually get some 600 grit sandpaper on the orbital sander and give it a very light onece over (after carefully removing the handle). Then one usually gets some areas of gunk which are removed with some laquer thinner and a razor blade. Then another quick touch with a new sheet of 600 on the orbital and done.
The problem with this approach is that it doesn't work for the teeth. I have done a number of saws where I pounded the set out of the saw, done this, regulated and reset it. Works fine. But in my kinder gentler old age I just use some wd-40 and fine steel wool. Sanding does bring out the etch - not so much with steel wool, but lately I like the unmodified patina better.
Tom Colligan
>Paul, Dave gave some sound advise. A modified way of sanding would be to use a hard block and some 600 grit paper with, perhaps mineral spirits as a lubricant. Again, a hard block so you'll be on the surface and less likely to remove the etch. A real fine oil, that's used to free rusted bolts and nuts, can lift rust on a table saw top so it would likely help coating a handsaw (I just can't think of the name of this popular product right now). Hope this helps, Tom.
Moses Yoder
Moses Yoder
>Mix 1 gill neats foot oil and one gill boiled linseed oil. Sprinkle some rottenstone on the saw. Dip a wool rag into the oil mixture and scrub the saw. Polishes all sorts of metal.
I got this off a website somewhere and tried it and it works good; I may even remember which website someday.
Mike Holden
>Okay, how about a translation of gills to ounces or milliliters?
Realize that it is a one to one mix, so volumes are not critical, but I would like to know how much is a gill.
Thanks,
Mike
Gill
>is a quarter pint (some places in England it is a half pint) and is not pronounced the way it is spelled but like 'djill'.
Stephen
Razor blade
Adam Cherubini
>I think a razor blade does a pretty good job removing rust. I think trying to get an old saw to look like a new one is a waste of a great deal of time. A razor blade, followed by wet sanding (600 is pretty fine) seemed to work best for me.
I've had great luck soaking rusted old parts in kerosene (for months at a time). If you had months and a tupperware storage box big enough, this could be a reasonable alternative to elbow grease.
Adam
Todd Hughes
>Ive cleaned up many dozens of saws...this is how I do it
If you can take the handle off do so..if it has split nuts don't fool taking it off because can be hard to get screws back on and have them look right.
Lay the blade on a hard flat surface and with a sanding block and somthing like 200 300 grit paper [ I bought a truck load of cheap Chi Com paper years ago that I use,,,don't know the grit for sure, don't worry] sand from front to back on the saw. I know lots of guys say put some oil on it and sand it wet..Ive tried it and man oh man is that a mess. Plus I like to save the rust dust from sanding it. Sanding it dry I have found to be quick, easy and not to messy. You are not trying to make the saw shine like it was new [or what you think it should have looked like when new] but instead a clean believable looking saw. Your sanding block will clean it up fine
Saws when made were ground front to back so by sanding front to back you will keep the saw looking original. A hard sanding block helps prevent the etch being sanded away. I have seen saws cleaned up using orbital sanders etc. and you know what? They always looked like saws that have been cleaned with an orbital sander. Your saw when cleaned up should look like a clean saw that hasn't been cleaned up...use a sanding block
... Tap the blade to get the dust off , put the handle on and then oil the steel.
...I have tried razor blades and for a very rusty saw they might be good to use befor switching to your sanding block...but why are you buying saws this rusty? .....Todd
Marv....... Northern California Lake Co.
>Hi paul,
Everyone seems to think your saw is rusty. You didn't say anything about rust. Is it rusty?
If it isn't rusty and all you want to do is bring out the etch a bit more, go ahead and use a sanding block and start with 400 grit wet/dry sandpaper and use mineral spirits as a lubricant. This helps keep the sandpaper cleaned out, at least for awhile. Do as Todd says, and sand from end to end, that's the way the blade was ground. Stay away from the teeth, don't sand the teeth.
Whatever you do, do not hammer the set out of the teeth and then try to reset them. An excellent way to break teeth off. Some of the older saws have some hard spots or the metal is just a bit on the brittle side. You are dealing with spring steel, not soft steel.
Keep in mind though, Disston didn't always do a good job of etching. It could be, no matter what you do, you won't make it any better than it is.
600 grit sandpaper will plug up almost immediately, that's why I say to use 400 grit to start with. If it is rusty and it's so thick that you can't see bare metal, you'll need to start with maybe a 220 grit then graduate down to finer grits.
And if the rust is bad enough to need scraping, don't use a razor blade, they are almost useless on a badly rusted saw. Use a box scraper blade. Much sturdier and wider too. And use mineral spirits even when you are scraping. The solvent tends to soften the rust just a bit and less chance of scratching the blade.
Don't remove the handle unless the blade is completely covered with rust.
As for a sure fire way to clean a saw blade, you have just read about 7 different sure fire ways to do it.
Have fun,
Marv
Um, Todd...explain, please
>"Plus I like to save the rust dust from sanding it."
And for what of your many interests do you need rust dust?
Paul Londo
>Thanks for all the help! Yes the saw has some rust w/one spot right in the middle of the etch right below the diston logo over the top of the #7 . My woodworking partner and myself have been working on a project to restore a working carpenters shop at Pinecrest Historical Village in Manitowoc County ,WI. We have been supplying some of the old tools ourselves to add to the collection the site already has (an awful lot of wood and rusty planes!) so when I found this saw for $3 w/ a nib........ We have a lot of tools to clean up and have been looking for a way to work on the saws.
Re: Um, Todd...explain, please
Todd Hughes
>I mix it with acid to make a wood stain plus I keep a bag of it and vacum cleaner dust to pit antiques in I used to make to age them up....Works great....Todd
>Paul,
I've run into quite a number of saws with rust only in the etch. It doesn't like to come out or off. When you sand that area, you will want to sand the entire side of the blade so it will all look pretty much the same. Do use a sanding block though instead of only your fingers. Doing it with your fingers will tend to remove more of the etch than with a block.
I like using mineral spirits because it doesn't evaporate very fast and it doesn't smell too bad and it's easy on your hands and it's thin as water. The low viscosity does a better job of cleaning the sandpaper as appossed to using a light oil or WD-40. I use an old paint brush to apply it, that way I only use the amount I want. Should you use gloves? Probably, unless you have hands like leather. Mineral Spirits is the only solvent I'll use without gloves. I use paper towels to wipe off the rust as when you have a brown slurry of it. If you wipe it often, it's faster to get the rust off. I use the towels until they fall apart.
I found a plastic handle/holder for the box scraper blades at Home Depot. It's designed so the blade can be used just like the razor blade holder is used. The best way I found to use the box scraper blade is to not push it, rather, hold almost vertical and use a pulling action with the blade at a slight angle, causing the blade to kind of slice the rust off. You can do this right over the etch so you can get most of the rust off before using sandpaper. But I would only scrape it if the rust is thick and hard.
If you intend to recondition other handsaws that are badly rusted, remove the handle and scrape the entire blade, scraping lengthwise. Often times you can get most of the rust off with just scraping. There is different kinds of rust. Sometimes it is so hard, the scraper won't take it of. In those cases, you will need to depend on a course sandpaper, like 150 grit or so and just keep sanding until you break through that hard crust. Then you can start using finer grits in stages. All you really want to do is get the blade really smooth and not worry about trying to get it shiney. If the blade is smooth, even if it is pitted, it will still cut well, if it is sharpened properly. I used to shy away from badly rusted blades, but sometimes if the saw is good in all other aspects and it is a good old collectible one, in most cases, it's worth the effort if you intend to keep the saw and not sell it for profit.
Marv
Re: Gill
Mike Holden
>So that's a soft g and either 4 or 8 ounces avoirdupois depending on geographical location - yes? (grin)
The only other place I have seen gills used is in reference to distillery workings, but could not determine the volume by inference.
Thanks for the clarification.
Mike
Re: Gill
Mike Holden
>Actually, I just googled gill
"Gill (measurement)
Imperial unit of volume for liquid measure, equal to one-quarter of a pint or five fluid ounces (0.142 litre), traditionally used in selling alcoholic drinks.
In southern England it is also called a noggin, but in northern England the large noggin is used, which is two gills. "
So a gill is 142 milliliters whereas one quarter of a pint (american) is 118 milliliters.
Intriguing. Stephen if we ever meet I will buy you a noggin of your choice of beverage. L'Chaim!
Mike
I can drink a Rundlet of Beer...
The evidence, then,
>is that life in northern England is a whole lot harder, so they have to drink twice as much.
Wonder if they have twice as many twelve-step programs?
