Re: Rockwell Jawhorse
ThomD
>OK, I was going to leave this to someone who had used one...
For real wood working I would try someting more traditional if you are interested. Nothing like conventional benches and vises for really getting a grip on stuff. Things like the Workmate, are clever, but not really serious for most things. It is an admirable attempt to pack a lot of stuff into a light and collapsable form, but at the end of the day a real bench is just adapted from some horses with a heavy beam or plank on them. That nocks down, works extremely well, is cheap, it is probably a little heavy. I have used my portable version as scaffolding at times. The beam can be a torsion box of plywood for lighter weight but great stiffness and flatness, You go to home depot and get a sheat of their best ply, up here that is maple finished, D-fir cored stuff that is about 40 bucks a sheet. You get them to rip it up so you have enough pieces for top and bottoms, side, and spacers. YOu need a bunch of spacers that will make a given are solid for mortising. Otherwise about one spacer per foot and the ends. Mine is about 8-10 inches wide and 4 or 5 inches thick when finished.
I don't live near huricanes, at least not southern ones. So from great ignorance, I would say if they were an every day part of my life I would get those steel shutters that have C-channel as a window trim element, and one gets a lot of stamped steel bits that just slide in over the windows.
If you want to continue to handle sheets of ply. Get something that will place a cleat under your window, so you can rest one edge on it and flip it up. Possibly some kind of saw horse that leans agianst the wall, or something that holds the adjustible ends of pipe clamps like an adjustible edge. The jaw on the RW is sorta the wrong angle from what I understand of your purpose. It might work, but I would think it would work better if the jaw were not perp to the body of the horse.
