Files, really old files
Wiley Horne-- So. Calif.
>I am curious about early mentions of files. Saws had to be sharpened, going way back. Did Roubo talk about files? Was just looking through Moxon, to see if there is any mention of files. Nope. Smith's Key, though, in the early 1800's, has about as many types and gradations of files as you will find today in the Grobet catalog, and the nomenclature has not changed much either. Quality of manufacture appears to be high, also, judging by the toothing.
What early references do we have to files?
Thanks, Wiley
Re: Files, really old files
MikeW
>Hi Wiley,
If I recall correctly, the book Roman Woodworking talks about files from their period, both makers/making and use.
Take care, Mike
>Mike,
I didn't think to check! Duhhh. Will do so.
Wiley
>Mercer talks extensively on files, including Roman. He points out that Moxon overlooked files, but Holtzapffel makes mention of their manufacturer.
P.S. Stubbs is probably the best known English maker, he corresponded with Smith for his Key.
Stephen
Re: Files, really old files *LINK*
Peter Evans
>I am in the process of compiling/writing a Directory of British Filemakers, probably a year before the draft chapters will appear on the Internet for comment. There are no comprehensive references. The two books on Peter Stubs are good for a look at the end of the 18th century. Files were critical to the Industrial Revolution and reached the equivalent of modern files by the late 18th/early 19th century, all hand made of course. The main problem was the quality and availability of steel.
There were hundreds of filemakers in Britain, mainly Sheffield where filemaking was well developed in the 17th century, and to a lesser extent, Lancashire. Files are no longer made in Britain.
Look up books on Stubs
Joel
>There is a book on Stubs and the English File industry. It's mostly on the side of business development and not much on the details of the files themselves. It is however an interesting read. "Peter Stubs and the Lancashire Hand Tool Industry" by E. Surry Dane
Also look at the catalog of John Wyke
Don McConnell
>Wiley et al,
Moxon does, in fact, mention files. In the Joinery section, sub-section #26, "The Use of the Saw in General," he discusses mounting the saw in the "Whetting-Block," in preparation for sharpening, ... "then with a three-square File they begin at the left hand end ... ."
Additionally, in his section on Smithing, he has three pages devoted to "Of Filing in General." It begins: "The several sorts of Files that are in common use are the Square, the Flat, the three Square, the half Round, The round, the Thin File, &c. All of these shapes you must have of several Sizes, and of several Cuts. ..." He then goes on to discuss Course-tooth'd files, Bastard-tooth'd files, Fine-tooth'd files and Smooth-tooth'd files. A fair amount of detail for the period.
Hope this helps.
Don McConnell
Eureka Springs, AR
Joel
>There is also A video from the English chapter of the SIA showing a filemaker making a file.
patrick gibbons, katy, tx
>I know Weygers relates how to make your own files by case-hardening the metal. I would suppose that 18th-19th century files of the best quality would be tempered but blister steel was used then and could probably make a pretty good file also. It's interesting that such a pedestrian tool as the file is so important; then and now.
Jim Crammond in Monroe, Mi.
>Wiley,
Though not a mention in the literature, the tool inventories that were in the Benjamin Seaton tool chest contained to references to saw files. In the original inventory of tools purchased by Seaton's father, Joseph, there is reference to "12 hand saw files, 12 sash saw files and 6 dovetail saw files." In the second inventory of additional tools presumed to be purchased by Benjamin Seaton, there is reference to additional hand, sash and dovetail files.
Jim
>Don,
Thank you very much! On behalf of all. I made a clean miss in regard to Moxon, which you have now made good.
That _is_ a lot of detail. The reference to the many types of files and many different cuts, all being obligatory to have, would seem to indicate that file-making was well advanced ca. 1700, whatever the difficulties were with obtaining steel.
I got interested in files in reading about an old Roman shipwreck the other day. An article was found which turns out to be a sophisticated calendar machine. It's not far-fetched to call it an analog computer. This machine used bronze gearwheels to determine the dates of eclipses, Olympic games, and so forth. Scientists date the machine back to 150BC. If interested, see
http://www.guardian.co.uk/science/2008/jul/30/archaeology.astronomy?gusrc=rss&feed=science
This Antikythera machine called to mind the nature of toolmaking, and the realization that the file enabled the making of all other machines, and I suppose most other tools. But then making a file requires considerable practical knowledge of steel tempering and managing hardness (what is the tool which tooths the file??).
Anyway, I brought all this to the experts to find out how much we know collectively on the subject.
Thanks again,
Wiley
numerous references
Bill Tindall, E.TN
>In the compilation of records from the Chester Co PA Courthouse there are references to files in the belongings of the early cabinet makers.
Joel
>A file is toothed with what looks like a very short carving chisel (double bevel). When I was last in the UK Ken Hawley gave me a quick demo - he's pretty good at it - but pointed out that the actual toothing of a file isn't that hard to learn and it's why you routinely saw women work the smaller files. Practice and piecework is what is needed to develop speed. And of course files have fewer teeth than rasps - which are harder to make. What file making does need on the larger files is strength.
The big thing is of course the steel selection, the softening and then hardening without burning the teeth.
Todd Hughes
>I sort of collect early hand made files...I just got it into my head that I should have some, I soon found out that these things are pretty rare to find. Took me about a year of looking befor finaly finding my first one.
I used to make lots of knives out of files so I looked at and bought lots of old files but still never saw any handmade ones. Finaly one day I was buying some files off this old guy for .25 cents each and all I needed was 1 more to make it an even $2 and he digs around in this old bucket and pulled out...yes a beautiful [well to me] big hand made file. I was about excited as I ever get over an old tool.
Had a great stamped name and a mark of a half moon as well as the file cutters number. I have read that many of these files were made by contractors in cottage industry, many of who were women, and this was how they kept track of who made what and got paid.
...Since that first one I have gotten more then a few other hand made files, once found about 1/2 doz. wrapped up in an old tool box.
I think the reason these old files are so hard to find today isn't because they didn't make millions of them but because since they were a good choice of steel so many got turned into other things.....Todd
Ray Gardiner
>Possibly as good a reference as any is (surprisingly) the Disston book
"The file in History"
http://www.wkfinetools.com/hUS/saws/Disston/04pubs/1922-FileInHistory/1922-fileInHistory.asp
There is a link on that page to download the pdf, but ... careful it's 12 Mb
But covers early history quite extensively.
Regards
Ray
The File In History
nicholson!
paul womack
>If you do a google book search for
treatise files rasps nicholson
you'll find a nice book to read.
BugBear
Peter Evans
>This may be the DVD that Joel is suggesting:
There are a number of early 19th century cyclopaedias on google books and internet archive that discuss filemaking; and many seem to be recycling the same material, eg Appleton's Dictionary of Machines etc 1869, or Engineer's Encyclopaedia etc 1849. Interesting reading.
filemaking dvd
Joel
>Yip - that's the DVD - if you are at all interested this DVD is great and the company has lots of other interesting DVD on other industrial subjects
Pam Niedermayer, Austin, TX
>Good thing he had all those cheap women who could learn to do the simple tasks.
Pam
Ya trying to pick a fight?
Scott Burr in Ben Lomond, CA
>Come on now...
I thought maybe Joel was. (: I know you are.
I doubt Joel meant to be quite as condescending
>as it sounded - certainly, it's a sad historical fact that women's wages have been lower than men's.
Re: I doubt Joel meant to be quite as condescendin
>Me, too, pretty much; but the more such statements are made in a matter-of-course manner, the easier it will be to maintain the status quo. The next guy can convince himself that it's OK to pay women less since every guy before him has.
Pam
Enough, please
Re: Enough, please
>Well, sure, Wiley. I figured you'd be offended and not particularly interested in whether a woman may have been offended. Got to keep the boy majority happy.
Pam
