Have a question? Ask Woody!
Yet another hide glue question
Bill Tindall, E.TN
>It is stated that one of the compelling advantages of hide glue is quick tack. I am not experiencing quick tack. In fact I am experiencing tack that is slower than yellow glue. Is it likely my glue has too much water? I mixed it 1 part glue and two parts water, by weight.
Another advantage of hide glue that I have never heard discussed here came up at the recent SAPFM meeting. Hide glue does not interfere with analine dyes commonly used to color period furniture. It makes sense that this would be the case because these dyes are similar, if not identical, to dyes used for wool. The interaction of the dye and wool, a protein, would be the same for hide glue, also a protein.
Re: Yet another hide glue question
Wiley Horne-- So. Calif.
>Bill,
Good thought on the non-interaction with aniline dyes.
On the glue, what is the consistency off the brush or stick?
Wiley
Dean J in MN
>Bill --
Try this -- put a drop between your fingers and squeeze and rub. The glue should grab pretty quickly and if you pull your fingers apart you'll find a spider-web like fiber between your fingers. If it doesn't grab quickly wait a bit and see if you can get that little web to form. I'd guess it is just a bit too much water.
-Dean
If you want a fast and aggressive tack
>try the fish glue from Lee Valley.
And aniline dyes are for period furniture made after 1850, when it was developed.
Stephen
Ace Karner
>I usually mix one to one, let it set at least a hour or two before I heat it in the pot. Then if it's too thick I can always thin it a bit with the hot water from the glue pot. Believe me when you get it right setting up slowly will be the one problem you'll never have, I tend to preheat most of my joints if I have a glue up with more than a couple of joints.
Stay with it, it's worth the effort for sure.
Ace
About the dyes
Warren in Lancaster, PA
>Usually when hide glue squeezes out it is already on its way to gelling and forms beads which can be removed, rather than soaking into the surrounding surface. Hide glue also remains water soluble after it dries. If there is a little residue around a joint, water stains, whether natural or synthetic, will color the area like the surroundings. If you contaminate your surface with white or yellow glue, they form enough of a barrier to the stain that there is an unsightly blotch of unstained wood.
Paul Kierstead
>I can honestly say I have never, ever, had a tack problem with hide glue. Had problems beating the tack, but never not beating it.
I'd have to say *way* too much water, or it is actually gelling before assembly. Or it is "bad", but I don't see how that could be the case.
Chuckb
>Bill, If you are having problems, maybe we can help. http://www.ptg.org/
on the lower right hand corner you can search our archives. Sorry, Piano Technicians Guild, that is. We have lots of uses for hide glue, and when you are glueing say, 88 new hammers into 88 new shanks all with hide glue, you get used to it real quick. I make a simple double boiler on a w-mart one pot stove top electric plate with a empty salsa jar in a pot with water. I usually fill an inch or two of glue granuals then add water until the granuals are just barely covered then stop. Bring it up to 150 and then adjust the thickness from there after about an hour. I usually like it a little thinner than honey. If it is chilly in the shop I'll go a little thinner. I love it for rub joints. Panel glue-ups leave a bit to be desired..
chuckbeck
Re: If you want a fast and aggressive tack
tstock
>Both fish and hide tack fast if the hide is 192g to 315g or so, relatively fresh, and the viscosity of warm honey. I use a batch of hide for about a week, storing it in a jelly jar in the fridge between sessions.
I like fish for it's open time, and use it for joints which needed some extra attention. That said, the more you use hide, the faster you get, and the less you need other glues. A good way to buy some time when starting out with hide is to heat the components to be glue. After a period of time, you'll find it is seldom necessary if the shop at least in the upper '60s and there's no strong drafts.
On squeezeout, if the joint is warm, I'll get a smooth ribbon of glue which is still liquid. If the work is cold and the glue begins gelling during the time you apply pressure, the squeezeout will look more bead-like.
Here's a shot of the Rival rig that was mentioned. Don't forget the candy thermometer for temp...when you start seeing the temps swing 40 degrees, it's time to clean the temp controller or dump the pot and buy a new one. FWIW, if you are going to use hide on a day-to-day basis, the larger 1 qt Hold-Heet pot is a good investment and will not wear out in 3-4 years as does a $12 Rival. On the other hand, I can buy 9 Rivals for about the cost of one Hold-Heet. If you do opt for the Hold-Heet, The Best Things carries the larger pot at a good price, and is large enough to take a ply cover with openings for a jelly jar and a squeeze bottle (for small jobs, a 2 oz squeeze bottle is faster than a brush and easier to control).
Re: How do you clean the temperature controller
barry vabeach
>I have the Rival and am starting to get swings in the 20 to 30 degree range- how do you clean the temperature controller? Do you mean the thermostat itself needs to be cleaned or something else?
tstock
>If you pull the bottom of the pot (a couple of Phillips Head screws), you'll see the temp controller. Clean out any carbon or surface contamination with fine wet-or-dry and some naptha. Works some of the time, but it may be that the bimetal strip fatigues, as after a cleaning or two, they seem to be less willing to stay within the 5-10 degree range seen with new pots. Hide will work even when cooked to 180 degrees, but loses strength and should not be reheated.
I'm on my third Rival in five years, and will replace it next time with a 1 qt Hold-Heet. I have the pint model, but it's a little small for use as a water bath for both jelly jar and squeeze bottle.
