Adam: A&M Forme Question
John Hoffman
>Hi Adam, I enjoyed the recent article.
Concerning the faces of the legs (where the mortis is cut), they appear to all be a bit off, as in not S4S. So isn't the top and bottom rail entering the legs at differnt angles? And doesn't this make joinig the other rails into the other legs a problem?
Thanks
JH
Re: Adam: A&M Forme Question
Not sure I followed you
Adam Cherubini
>The legs certainly aren't S4S. I tried to get them S2S. If I understood the question, the mating faces need to get planed before turning so the upper and lower pommels are in one plane. The center legs do need to be pretty close to parallel.
If you are referring to the picture on pg 26 showing the legs all turned, I cherry picked the best legs and best sides to reduce the problem you are talking about.
So if I understood you, yes it's a real problem. And legs that taper or appear bowed like those on pg 26 certainly would be a problem.
But it's actually not hard to fin good legs. The end legs need to be have two pretty square faces. The middle legs need parallel faces. The inner stretcher can be sloppy. I made sure mine were pretty clean, though.
This was kind of a tough job. I promised my wife two more of these and haven't gotten around to it. I've been asked to make these commercially and the price lost me the job. I wish this was a two day job but it just isn't. I can make the refectory table shown in the background considerably faster. There are far fewer joints and I used sawn lumber for it.
Adam
Re: Not sure I followed you
John Hoffman
>Yes that was exactly what I was asking about because it did look like the faces were not square to the rest of the leg which would cause the tennons to enter at different angles and subsequent problems arise.
Thanks
JH
Bjenk Ellefsen
>While we are on the subject of the Forme you built (looks fantastic by the way); what did you mean by attaching the top with pegs?
Adam Cherubini
>They basically toe nailed the top to the legs using pegs. My experience doing this isn't great. You want slightly tapered pegs and I think you need to glue them in place. For a variety of reasons, I chose not to do this. I screwed a few cleats in place inside the aprons and installed screws up into the top from underneath.
Adam
Bjenk Ellefsen
>Oh jeez, ok, now I see. I wouldn't feel confident to ever try this.
