Re: Panel raiser questions
Wiley Horne-- So. Calif.
>Bjenk,
We may have a nomenclature problem. I am interpreting 'step' to mean the beveled edge of the raised center portion, known as the field.
First, let's go back to what Warren said. I think he is right in saying that your panel raiser does not have lateral taper to its sole. Some panel raisers have a flat sole, with a beveled step, and with the blade having a bevel-cutting return on it. It's a panel raising and fielding plane. This type of panel raiser is designed this way so that it is flexible in regards to the bevel angle, bevel width, and thickness of wood that you wish to work. You don't have to start with a specific thickness of wood, and you can plane whatever slope of bevel looks best to you. I think that is what your plane does. However, you pay for this flexibility by the fact that you're going to have to tilt the plane to get the bevel you want.
Another basic type of panel raiser is the one shown on Philly's site. It does have a specific lateral slope to the sole. Now with this type of panel raiser, you hold the plane vertical, and keep it vertical throughout the planing. The geometry of the sole takes care of the rest. This is a simpler situation, but then you are dealing with a narrower range of possible geometries and a narrower range of wood thicknesses (in theory, anyway). [By the way, I have Phil's mini panel raiser, and it really is an excellent performer, and came that way from Phil. I ordered the plane because I got green with envy when I saw Mike W's example.]
So what does all this mean on your planet? My suggestion is that you first draw out the profile that you want on the end and edge grain of your board. You won't always need to do this, but it would help in getting started because you'll be able to see your progress more clearly.
Does your plane actually have a spring line? I don't know why it should, because it is designed to be flexible with respect to the bevel angle you can cut. You tilt the plane at the angle you want to put on the panel's bevel section. Start planing, and just as shown on Philly's video, the first cut should take only a narrow strip off the board edge, the second cut should widen and deepen the first cut, and so forth until the full width of the bevel has emerged. You can track progress from your end and edge grain marks. When the bevel is at full width, then the very next cut should begin to define the field. The bevel should begin to sink down below the level of the field, revealing a deeper and deeper field. Stop when you hit your marks, or whenever you're satisfied with the depth of the field.
Troubleshooting: Let's say the above is not happening. Suppose at some point, the bevel you're shaving is deepening at the edge, but not widening and the field is not emerging. One possibility is that you are tilting the plane over more as you proceed, so that the outer edge of the blade is never going to make contact. If the bevel stops widening before it is at full width, then suspect this. However, even if you are maintaining the correct tilt, it could be that the blade reveal is not even all the way across its width, and in fact is not at cutting depth near the outer edge (where the field will be defined). So double check whether you have a good even reveal of blade. One other possibility, if the plane tilt is right, and if the blade reveal is even, is that the blade may be sharpened too steeply, so that it does not have enough clearance angle over towards its outer edge, and can't get a bite for that reason. Or there may be a bump on the sole ahead of the cutter which is preventing the blade engaging the work.
Any of this make sense when you look at your plane?
Wiley
