dado question
dado question
dado question
Bill Tindall, E.TN
>What would have been used in days of old for making a dado across the grain? Is there a modern electron-free equivalent?
Re: dado question
Any rabbet with nickers on each side
David Miller from Iowa
>Although I have had better luck going cross grain with a a skew blade. A #46 works good if you are close enough the edge to use the fence. You can't beat a #39 for this work - just clamp a block of wood on the workpiece as a temporary fence and off you go.
david
Re: dado question
Re: dado question
Dean J in MN
>A dado plane of course. :) Nail on a batten and zip-zip you're done.
For case pieces I dado both sides at once. I place each side front-to-front, nail the batten in place and cut the dado. (Front-to-front is to allow any blow out you may get from exiting a cross grain cut to end up in the rear of the case. That blow out is removed by cutting the rabbet in the rear edges anyway)
-Dean
Re: dado question
Re: dado question
>If you don't have a dado plane (or one of the correct size), then use the fence trick and with a crosscut saw, cut both sides of the dado to the depth and remove the excess with a chisel and router plane set to the proper depth.
Stephen
Re: dado question
question
Bill Tindall, E.TN
>What is a 39 and were can one be bought?
The new LV dado plane says something about it not working well (or as well) cross grain. Is it unsuitable cross grain?
Re: dado question
Re: question
Dean J in MN
>LV has a dado plane?
-Dean
Re: dado question
Re: question
Warren in Lancaster, PA
>If it isn't designed for cross grain work, it is not a dado plane.
Re: dado question
Re: question
MikeW
>Stanley #39 planes come up on eBay, Leach's list and various old tool dealers.
The plane of LV's I think you are thinking of is the plow. They are not very ideal for dadoes or cross-grained rebates.
Stephen's method works well. I use it for most of the stopped dadoes I have done when using hand tools.
Dedicated dado planes have depth stops, skewed blades, nickers that score ahead of the cutter on both sides and a sole that is a skosh narrower than the blade.
This is a front end view of the Nelson dado planes. No picture of the side views or the other couple I have. But can snap a picture if needed.
For seeing a #39, go to Leach's web site. I have owned #39s but much prefer wooden dado planes--the metal ones are a tad uncomfortable for more than a couple dadoes worth of work.
Take care, Mike
Re: dado question
Re: question
Wiley Horne-- So. Calif.
>Hi Bill,
I believe the LV plane is a plough, and the last thing you would want to use cross grain.
The Stanley 39 is a metal dado plane. They're up all the time on Ebay, but you'll pay $75-100 (usually) for a good example. And they're majorly uncomfortable--cut into the palm of your pushing hand.
Mike's got it. A wooden dado. What size dado are you making? I'll be glad to send you a plane all ready to go. You fence it off a batten as others have said. I'm kind of a candy-#ss, so I clamp the batten down. The official way is to nail it.
Wiley
Re: dado question
Correction
>Sorry Bill. You must have meant the LV skew rebate. As shown in Marc's post above. Still won't work though because as Warren indicated, you need nickers on both sides of the blade to make a clean cut.
Wiley
Re: dado question
Re: Correction
MikeW
>Plus one cannot cut a dado narrower than the width of the blade. In the case of the LV rebates, it would be a wide dado indeed.
Wrong plane (like a plow) for making dadoes.
Really, using a saw (I like using a stair saw) guided by a batten, popping out waste and using a router plane to level is a fairly standard means of creating dadoes and rebates.
Take care--lunch is over...Mike
Re: dado question
Re: dado question
>I wound up researching several old texts, seeking one to respond to Bjenk's request in a thread below, and saw several references to this approach - so, to respond to Bill's original question, it does seem to have been common older practice.
Re: dado question
I agree
roninkokomo
>MUCH prefer wooden dado planes
Re: dado question
Nice matched set you got there!
Scott Burr in Ben Lomond, CA
