more hide glue questions
Bill Tindall, E.TN
>Is the following acceptable practice?....Keep in mind that I have never used hide glue so things like "looks right" or "feels right" are not helpful. I can measure weights precisely, as well as temperature.
I am using tiny amounts of glue to stick stuff down. I make up a 1/2 oz of glue in a 1oz bottle. When I need to use it, I set the bottle in hot water. When it becomes a cloudy mobile liquid with no thick regions (it becomes uniformly warm and fluid) I remove it from the hot water and use it.
Re: more hide glue questions
Dean J in MN
>Bill --
I would watch your glue to be sure it doesn't cool too much after you pull it from the hot water. It isn't clear if you put the bottle back after each application or are pulling it out of the water and using the bottle for a while. The small volume of glue will cool pretty quickly and you'll find your working time will be even shorter if you start with a glue which is starting to cool.
If the glue is gelling before you can get your parts together return the bottle and let things warm back up.
I find small baby food jars work well if you only need a small amount of glue. Leave the jar in the water bath and apply with a brush.
-Dean
>Bill,
Perfectly acceptable. One way to test viscosity is to dip a glue brush into the glue and lift it above the warmed glue, (about 6 inches above the pot) the glue should flow freely from the brush in a steady unbroken stream. If it doesn't flow off easily, it is not warm enough or not thin enough to flow freely. If it forms and breaks up into drops as it flows from the brush, it is either too warm or too thin (too much water).
I hope that helps.
Stephen
gel question
Bill Tindall, E.TN
>is gelling when the liquid becomes fairly rigid like when it is cool?
Re: gel question
Dean Lapinel
>Not quite. It is more like a rubbery goober-like substance. if this is what you get as squeeze out then start again.
Re: gel question
Dean J in MN
>As the other Dean said -- a goober like substance. If you've ever used rubber cement -- you know how you can roll it up? If you can do that to hide glue you're far beyond the point you can make a joint.
-Dean
Goober like? Peanuts?
Pam Niedermayer, Austin, TX
Hey Bill
roninkokomo
>This hide glue thing is a lot easier, Than some people think. I just paid 2 bucks for an old potpourii cooker at a flea market. Mine looks like a minature crock pot. It works great. I mix up about half a cup at a time.
Ron
