manhogany stain
manhogany stain
manhogany stain
Bill Tindall, E.TN
>Does anyone have a favorite stain for reproduction work in mahogany?
As an experiment I fumed a test piece with ammonia and got a nice red brown, but I don't know if it is a stable color. I'm wary of chromate because the surface must be sanded after application and the chromate laden dust will be carcinogenic if inhaled.
Re: manhogany stain
Re: manhogany stain
James Watriss
>I dunno about the sanding bit. When I used potassium dichromate, I raised the grain and sanded first, then laid down the dihromate solution. After it dried, the piece looked fairly orange in color. I wiped off the residue with a damp rag, but as soon as I applied the varnish to that piece (Waterlox) the piece really turned a beautiful shade of rich reddish brown. I've also used the same idea, only using garnet shellac, turned out just fine.
I was careful to wear gloves, and I wore a dust mask, but I didn't feel any after effects at the time. And the piece still looks great.
Re: manhogany stain
Re: manhogany stain
>I like Alkanet Root and linseed oil, makes that nice old purple/red color you see on a lot of old pieces of mahogany and rosewood. It is however a fugative stain so it will fade on exposure to sunlight.
Stephen
Re: manhogany stain
Re: manhogany stain
>Bill I use red analine dye followed by Brown shoe polish. I love the old style mahagony look it gives the wood. You can vary the red by adding yellow, or blue, and I have used Cordovan shoe polish as the last color as well. I seal them with shellac and then finish with my normal lacquer finish.
Re: manhogany stain
Re: manhogany stain
Dave Anderson NH
>I'm a mordant kind of guy with mahogany. I've always used lye and then garnet shellac as the topcoat.
Re: manhogany stain
does it seem to be light fast?
Bill Tindall, E.TN
>I got an off hand comment from Jeff Headley that the lye color was not as light fast as chromate. The lye makes an alarming bright red. Does it tone down with subsequent steps?
Re: manhogany stain
Re: does it seem to be light fast?
John W
>Bill,
In my experience lye works well, beautiful color, but it is not lightfast over the years. You can get the exact same colors using water based dyes without any other issues. You can get them here: http://www.wdlockwood.com/ Their customer service is second to none.
John
