hide glue questions
hide glue questions
hide glue questions
Bill Tindall, E.TN
>How long before the joint is near full strength? I was told that it sets by cooling but I suspect it really sets by cooling and loss of water. So I am presuming overnight?
The bag says mix 1 part glue to 1.5 parts water with no clue if this ratio is weight or volume. Another reference says 1:2 by weight. What is recommended?
This Federal piece I am building has overlays applied to the carcass front and a rub joint seems like a good application for these intricate pieces and joints. At least I am trying it.
Re: hide glue questions
Dean Lapinel
>Ratio is by weight but you can vary that to acquire the viscosity you desire. clamp time is really short...as matter of fact it can be rubbed together (the two pieces of wood) until the glue sets and no clamping is necessary. 12 hrs for is probably safe otherwize.
Watch for gel. If there is any gel formation in the joint then you took too long and need to start over.
I add 3% urea (by weight) to delay the set just a little.
Warren in Lancaster, PA
>Usually we say you can carve or chisel the piece after an hour, definitely faster than yellow stuff. The glue gets harder by cooling and drying, but the surrounding wood absorbs moisture (perhaps faster than other glues) helping drying. Today I was carving some leafy rosettes for an old Philadelphia clock and glued them to a work board for carving. I started carving about 15 minutes after gluing- kind of risky, but no loss if it had come loose. An hour would have been more prudent and overnight is safest.
I have never measured ingredients; it is best to have a feel for consistency and add water or glue to suit. There is fairly wide range of consistency that will work. If there are strings of glue going from your brush back to the pot it is too thick.
Wiley Horne-- So. Calif.
>Hi Bill,
Like everybody else, I'm on the edge of my seat waiting to see the project, and also what you found out at the classes you took!
If you want to measure, measure. However, what actually happens is that once you get the glue to temperature, you'll be constantly losing water, which will need to be topped up. So as Warren said, it's really more about managing the viscosity over the work session than starting out with any particular formula.
Patrick Edwards says you can just cover the glue with water, and that'll be fine. That's what I do, and it works. Cover the glue with cold water, wait until the glue gets fat, which will be 30 minutes to an hour (I'd guess, never really timed it for data). Then heat it. You will need some kind of a constant temperature device, so that is not an added management problem.
You can test the glue consistency by just putting a stick into it and watch the drops come off. If the glue comes off the stick in drops, it's on the thin side. When the glue is a little thicker, it comes off in a stream that holds together. Anything stickier than that is too thick, in my opinion. Sometimes you want a thin mix, if you want a little slower tack to rub the piece into place. So sometimes I like drops. Other times you want a fast tack, and go for the stream. There are faster streams and slower streams, like different molasses grades. So there's experimentation involved. The thing is, as Warren said, there is a huge range of usefulness, and even in the worst case you can just start over again if you think you got a cold joint.
You want to get the glue on both surfaces to be glued, whenever possible, because the glue strength comes in part from the key that it gets with the wood fibres--so the glue has a better chance to get that key when both surfaces are hit with glue while it's hot. Speed is better than neatness IMO, and the excess will come off easy. Let it get to a light gel and rake it off with anything.
Have a couple of wet towels around to wipe your hands off on.
Hemostats are great when working with veneer or small parts. One of the issues of working with thin parts is that if you apply the hot wet glue to one side (only), it'll curl like crazy after a short while. The solution to this (in my amateur experience) is to just dip the thin piece wholesale into the glue pot, bring it out dripping and press it into place with your fingers. This is why you need towelling around--to get the glue off your fingertips. The tack is fast enough, that for example, if you are covering a French foot with veneer, and the foot is curved and not too big, you can get a good tight tack by just holding the piece in place with your fingers for a half minute or minute, and that's a good tack. It'll pull itself together even tighter as it dries. The reason I mention this is that speed is important--any kind of fancy mechanical clamping has setup time associated with it, and it's possible to shift the work too when tightening the clamp. Often, you're better with 'finger clamping'-- which is very fast, and gives a very sure placement--as opposed to trying to get some wax paper and curved clamp onto the work. You can see the exact grain match you're getting.
If you want to do a clamp of the veneer, I would suggest having the wax paper preapplied to the matching face, so all you have to do is tack the veneer piece down with your fingers, hold it in place for about 30 seconds so you're pretty sure it won't shift when the clamp is put on it.
That's what comes to mind right off.
Wiley
When working with veneer, you have an issue
Dean J in MN
Not sure if you ran across the nuggett Don McConnell posted to the Old Tools list regarding hide glue ratios.  I've included the snippit below.
As others have said, you pretty much wing it for the most part.  Experience will be your guide as you use hide glue, but you'll recognize too thick or too thin pretty easily.  As a starting point the chart below has some quantitative information.
Brown and Tustison also give a chart for mixing hide glue, based on parts by weight. I haven't used it (not having sensitive enough scales) but thought it might be useful for those getting started with hide glue who might have a nice balance beam gathering dust.   ;-)
Grade     Kind of           Proportions              Min. shear-
of glue     wood           Glue        Water          ing strength
  A        Hard          1 part      2 1/2 parts        2,800 lb.
  A        Soft          1 part      2 parts            2,800 lb.
  B        Hard          1 part      2 parts            2,600 lb.
  B        Soft          1 part      1 1/2 parts        2,600 lb.
  C        Hard          1 part      1 3/4 parts        2,400 lb.
  C        Soft          1 part      1 1/4 parts        2,400 lb.
Not sure how A, B, and C grades correspond to todays glue classifications, but assume thinking good, better, and best would be ok as a general guideline.
Don McConnell
Knox County, Ohio
ThomD
>If i have a resonable container, not narrow like a test tube or flat like a pan, I just throw in the chrystals and cover with enough water to double the water height over the glue granule height. If I had 1" of granule I would have 2" in the pot after I added the water. I let that sit overnight until it is pudding like and just pour off the surplus water, and heat it up. That works fine for me, and I can always work in more water to thin the glue.
Dan Donaldson
>Not sure that good, better, best would apply to hide glue. It is rated by gram strength and which is best depends on the usage. The higher gram numbers are a bit stronger, but they also set up faster as the numbers increase. A high number would be appropriate where you need a very fast tack, but would not be a good choice for a long glue-up. For woodworking, most any of them are strong enough for the usage, so it is more the time that you would look at.
Just an aside, chip glass is made using a low gram number. You make a dam around the edge of the sheet, then pour in a layer of hide glue. As it dries, it shrinks and pulls out pieces of the glass to form a pattern similar to what you see in the winter on an old window from the frost. The attached picture is blue chip glass. To me, it is pretty amazing that it sticks to the glass well enough to actually pull out chunks of the glass.
