A closer Tormek relative...
John Aniano in central NJ...
>Hi All,
Over the weekend, Bill posted a picture of a "Tormek predecessor" so I thought I'd post pictures of a unit more directly related to the modern Tormek. Pictured is the Tormek ST-250, a wet grinder sold back in the early 1980's. The tool was part of the 1/4" electric drill accessory craze - some here no doubt remember that period. You can see the aluminum bracket used to hold the 1/4" drill body. The drill chuck spun a metal shank that drove the rubber friction wheel. The weight of the drill gave the frictional force to prevent slipping, in the same manner of the modern Tormek grinders.
I came upon this unit when a friend left his long-time shop in New York and left this heavy unit. I resurrected it by altering the motor bracket to attach a 1/2 HP motor to spin the friction wheel as well as mounting the conventional Tormek universal horizontal jig bracket. So now I have (2) Tormeks...
John
Re: A closer Tormek relative...
Re: A closer Tormek relative. & a pair of Tormeks!
Re: A closer Tormek relative - side view...
>Here is a side view of the modified Tormek ST-250. The motor barely fits into the more narrow width metal housing. I had to add cooling fans to keep the 1/2 HP motor from over heating, but even after just about 10 minutes of use, the thermal overload shuts off the motor.
Interesting how little the basic shape has changed
>No money being wasted on froo-froo decorative design changes there.
Man, Now that's a Drill Doctor!
Scott Burr in Ben Lomond, CA
