Yikes! *LINK*
Tony Sade (Charleston, WV)------WebKitFormBoundary
http://www.woodworkforums.ubeaut.com.au/showthread
Yikes! *LINK*
Clever, clever Rob
>subtly building up to pics of the crooked bunny planes.
Those are way pretty little things. Way pretty. I'm intrigued that LV has chosen the same depth stop design that Stanley used (though with some improvements) rather than the rod-and-foot approach used on the small plow. Actually, as I think about it, this makes sense, because it permits the plane to be used against a high edge (like a wall, that is, higher than the plane body). My first reaction to the tilted knob was not very positive, but, as I think about it, it makes sense for the same purpose - you can grip it without banging fingers.
Looking forward to Rob's explication of the design decisions, but wondering why he's giving out info to the Aussies but not to us...hiding hurt feelings.
Re: Clever, clever Rob
Rob Lee
>Well... I like to be an equal opportunity teaser, and the Australians need a boost after Phelps wiped them out... :)
Will re-post it here, so people won't have to leave the board to see it - but have to change the image link format first...
Cheers -
Rob
Hi Bill
I have only played with a plastic prototype, back in January, to provide feedback on the design. It was an incredibly realistic replica.
The knob (that cants to the side) is just great in that it facilitates pushing/holding the front of the plane against the work piece. The knob is comfortable, a good size, and unobstructed from other plane parts.
Copy of post...
Rob Lee
>Here we go (hopefully) - repost from the other board...
A walk through the shop�
Actually, a quick walk through the machine shop�
As you walk through the doors of our manufacturing facility, the first area you enter is actually our assembly area. Here, there are rolling carts with finished assemblies:
Stationary shelving with assemblies to undergo final inspection:
And even bodies that still have the QC tags attached. Each plane body has a checklist that travels with it through each of our manufacturing processes:
We use a lot of carpeting and cardboard to keep parts separate:
It�s often the wooden parts that get put on last in this area:
Stepping out of the assembly area (and putting on our safety glasses!) we head into the surface grinding area. Here you can see various bodies with QC sheets:
�as well as some unique bodies being ground..
It�s also in this area where we have some of our largest mills � each holding up to 60 different tools, and capable of some pretty complex operations. Here�s a �tombstone� with plane bodies mounted at all sorts of weird angles for some reason�.
Each face of the tombstone can hold multiple fixtures, or pieces of tooling. While not necessarily much to look at � these are executed in very hard steels, at high tolerances, and are the foundations for accurate and repeatable milling:
Mounting a part in different orientations lets us use one milled surface as the reference face for a subsequent operation � as well as positioning the casting so as to allow for machining operation on a different axis:
Of course, each step in the mill is choreographed, and can be easily seen by numbering the steps (and the tool used) on a casting�
At the very back of the building is where the real high-tech equipment is..
Here�s an automatic lathe turning out some sort of specialized part:
And, on a nearby desk, there are a few more! What�s interesting here � is that the �green tag� part can be seen! It�s the first part made in the run � 100% in tolerance and fully inspected by our QC department�
Here are a few other boxes of parts, with one shown after milling, and the first off�s lying nearby�
Darn � just noticed we spelled �traveler� incorrectly on that control form:
Another box of odds and end lying next to a small mill�
Back into the QC shop, we can see that the part being evaluated here is obviously being used for setup only�as it�s not painted. Why waste the additional cost painting a casting that being used to setup production.
And there are sure a lot of tolerances to check on some parts! A quick glance at the drawing shows lots of point of interest. Tacked up the wall by the CMM (a three dimensional measurement machine) there appears to be a drawing being used to set up inspection procedures�
Of course, QC is also checked at almost ever stage of assembly too:
What really kind of neat is seeing all of the parts come together at once. All of the shots in this post were taken over a period of about 40 minutes�. It not often that there are so many parts running through the machine shop all at once. You should be able to recognize many of them in the pictures of some finished planes below�
Cheers �
Rob
Tools to make tools
>Very interesting post. I just had one of those deep thought moments. It takes tools to make tools. And it takes tools to make the tools that make tools. And it takes tools to make the tools that make the tools....and......
Where does it start? ;-)
Thanks Rob.
Tom
You need the chicken tool first
Denis Ch�nard, Orl�ans, Ont.
>Then you get egg tools, that over time become chicken tools...
DC, aka Jack Handey :-)
Re: Yikes!-Kurt
ThomD
>Anyone who has ever priced a simple Kurt vice for their mill.... Tombstone indeed...
Ace Karner
>I sure haven't been able to handle one yet but I'm sure that I no longer have any desire to purchase an overpriced 289, I'll just wait til I can order one of these from Rob.
What a beautiful, well thought out design. And we have all learned that the production quality will be first class.
I'm spring loaded in the buy it now position Rob so the next move is up to you.
Easy answer
wilbur
>At the end of the line, there's probably some guy with a flint axe and a big rock. :@)
Alternatively, there could have been a mill and lathe created on the fifth day. :@)
Don't you need the dinosaur tool first?
Kinda like it takes a bench to build a bench!
Scott Burr in Ben Lomond, CA
Are you suer Ace?
>I've personally returned a few LV tools. Let's see how they preform befor jumping to conclusions....
Looks like
>just looked at picture 26 and measured the angle of the cutting iron - basic angle is about 45 degrees (probably right on 45, when you allow for the imprecision of my $1 General Tools garage sale layout protractor and the fact that the picture is not dead-on right angle). Since it's a skewed iron, the net cutting angle's a little lower.
So I take it this was a compromise angle for cutting cross-grain and long grain?
Another point: NOT YET SHOWING UP ON THE "WHAT'S NEW" LIST DANG IT!!! When will we junkies get our jones satisfied, Rob?
Oh, and
>I can see the set screws in pic 26.
I bet the screw for the depth gauge has a wavy washer built into it somehow.
Where's the magnet?
Re: Hence the term "rule of thumb"
paul womack
You can make a hammer from a blob.
You can make a cold chisel with a hammer and a grinding stone.
You can make a file with a cold chisel.
You can make a hacksaw (blade) with a file.
booting complete, system ready.
BugBear
