Waterstone Storage
Jerry Draper
>Should waterstones be stored in or out of water when not being used?
Waterstone Storage
Jerry Draper
Re: Waterstone Storage
wilbur
>Depends on which waterstone it is. Shaptons and natural Japanese waterstones are usually stored dry, and in use you just splash some water over the surface, and you're good to go. Many other artificial waterstones (Norton, King) need to be soaked for a while, usually 10-30 minutes or so, before they work well.
Having said that, I think that the storage in water thing is really just a time saving issue rather than a requirement. You might be able to get the same results by making a routine of sharpening your tools after you use them, storing your waterstones dry, then dunking your waterstones in a tub of water when you next start working in the shop. By the time you have finished doing whatever you are doing, the waterstones will have soaked long enough, and be ready for use to sharpen your tools before you put them away.
Brent in Montreal
>Wilbur's plan is a good one if any time will pass between using your stones. I use my Nortons more days than not and just leave them soaking, even the 8000 grit. I never experienced the break down of a stone that some mention being due to continous soaking.
Richard Jones
>Mine stay in soak all the time as well. An 800 and 1200 King, a 1000 Norton, and a 4000/8000 Norton.
No breakdown as of yet...............
Rich
Alan S
>I have an 800/4000 king that I stored in water, and the bond between the grits failed partly. The soft wetted stone warped and deforms easily enough that it's now impossible to flatten.
A similar 1200/8000 king stone I store dry, wetting before use. It has remained stable.
It's possible my delaminated stone was simply defective, and the storage in water had little to do with it, but I don't store combo stones in water any more.
I store my dry...
Scott Burr in Ben Lomond, CA
>Got tired of the crap growing on them in the water, yet alone the worry when the temp drops below freezing. It takes a few minutes to soak any water stone, so no skin off me.
