Veritas - Innovation in Tools
Stanley 289 depth stop
>Is the depth stop on the 289 identical to that on the 78? I know the fence differs. Is the thread on the fence arm something offbeat?
In case y'all haven't figured out from the questions, I'm watching a 289 missing fence, fence arm, and depth stop.
Re: Stanley 289 depth stop
steve mackay
>Not real sure about the depth stop but I'll watch this thread to find out ! In any case if you can get that 289 for a decent price (and they seem to stay that way sans fence) snatch that sucker ! You'll be glad you did ! You and I can fight over the next fence on Da'Bay latter on !
Don in Northern Arizona
>Bill,
The #78 depth stop will work fine on a #289. The thread is the same, and it fits in the groove on the #289. My #78 depth stop is about 1/16" shorter and 1/64" thinner, but that may be because it is a later model.
Does it have both retractable spurrs? If not they will be hard to come by as they are only shared by #10 1/4, I believe.
Don
Both threads are the same. *LINK*
>The fence rod thread and the depth stop thumb screw thread are the same on a #78 and a #289. Of course, the fence rod on a #289 is much thicker, but a #78 rod fits in the #289 thread. You can get reproduction parts for a #289 at the link below. The repro complete fence, rod, and screw is pricey.
Don
St. James Bay Tool Stanley Repro Parts
I just checked mine...And the results are in!
Scott Burr in Ben Lomond, CA
>Everybody here has it right! 78 parts work fine. I've bee bugging Jim Reed to get the set of nickers for them done as well.
Where are you Jim, I know your out there!
Interesting, then, that St. James Bay
>charges almost $5 more for a reproduction 289 depth stop and screw than for a 78 depth stop and screw. Must be some difference in the factory equipment.
Are you sure it's the depth stop and not...
>The fence? The 289's fence is different than the 78's, even though they are interchangeable.
Yep.
Finally went for $76
>not worth it. After I assembled a depth stop and fence, I'd be paying at least as much as buying one, and I'd rather spend the money with Rob.
It'd still be fun to have one; just have to examine the rust piles closely when I go garage saling.
Are you sure?
>$80.00 A 289 off ebay
$20-30 for a 78 for parts
$100-110 for a usable plane...
Priceless!
Re: I just checked mine...And the results are in!
Todd Hughes
>The fence for a 289 is NOT the same as one for a 78, is heavier, has equal front and back sections and has two holes for attaching a wooden wear strip and is mounted on a large diameter arm. A fence section for a 289 by itself books for $75- $150.....Todd
