Plans for hand tool projects
roninKokomp
>I was asked not long ago if I knew of a good source for plans for projects that were designed to be done with hand tools. I had to say that I did not.
Any help?
TIA
Re: Plans for hand tool projects
scott grandstaff
Plans for hand tool projects *LINK*
scott grandstaff
>My FL had a saying about project plans. It went something like,
"Are you kidding me?
You don't already have more projects than you are ever going to finish?"
I thought it was a weird thing to say at the time.
But stick around a little, he wasn't wrong.
Plans are mostly for stalling on the things you already need.
yours, Scott
fireaxe
Bjenk Ellefsen
>I think Mike Dunbar published a few of those in FW. There was an 18th Century cupboard (which I am building at the moment HEE HEE HEE) and there is a blanket chest too. Both are fine examples with dimensions and Mike tells you which tools you should use. Accompanied by his fantastic book on using and restoring old tools, its a blast.
You can always adapt projects that are based on old furniture and do them properly (that is how they were meant to be made) by using old tools. I did "The Schwarz" Shaker hanging cabinet reproduction by using my old tools instead and it was a fantastic project and so easy.
This is one of my pet peeves
Patrick Gibbons, Katy, TX
>Everything is pretty much designed for tailed apprentices. I usually have fun figuring out how to do it with hand tools. The problem is it usually entails moderate to major design changes. I'll use completely different joints, etc. Borrowing from another thread, this is what leads to a lot of false assumptions about the inadequacies of hand tools. Most projects need to be rethought out.
Re: Plans for hand tool projects *LINK*
A_Babar
>I was told that this is a good source:
http://digicoll.library.wisc.edu/cgi-bin/DLDecArts/DLDecArts-idx?id=DLDecArts.ChippGentCab
There are plans for just about anything you want to build.
A. Babar
The gentleman and cabinet-maker's director: being
confused by the question
Bill Tindall, E.TN
>Anything can be made with hand tools, or combinations of power and hand tools. However, some things can't be made with all power tools. Hence, I am confused by the question. Are you looking for projects that can be easily made with hand tools?
Pam Niedermayer, Austin, TX
>You may want to check out these plans. As far as "for handtools," the main thing you'd have to do with, say, Norm's plans, is to cut longer pieces so you can use M&T, dovetails (even though Norm does these by machine, you can use a saw/chisel), etc. In fact, most of the fun watching Norm is translating his work into good joinery.
Pam
Carlyle Lynch plans at Joel's shop
Isn't that why . . .
steve mackay
>we use the hand tools ? Figuring out how to do it sans power ? And not only the challenge but, lets face it, if you've got the time, in most cases hand tools do the job better than power. Sorry, knee jerk response there.
Bob Rozaieski
>I documented an all hand tool build on another forum a few months ago. I did some editing of that post and put it here:
My Version of Dunbar's Colonial Cupboard
Re: This is one of my pet peeves
Bjenk Ellefsen
>Yes, it does take adjustments. However, I find that with experience, you don't even look at the steps being referred to. I look at the general dimensions and just get to work. You eventually know what to do with a generic plan. Things are so easy when you know your tools and how they work in relation to one another.
I just did the dadoes on a cupboard for my daughter's room. Two long dadoes in both sides of the carcase done in two go. 5 minutes each with a batten nailed directly into the sides!
When the tools are tweaked properly and you have gained confidence with them, I find things are much more logical and straightforward than building anything in a "home manufacture". Sorry for the controversial opinion.
Hey guys
roninKokomo
>This is Ron. I've been here for a loooong time. I know most of the short answers about hand tools. Like if you have enough time you can build about anything with a knife and a mallet. I am just trying to get a little help for a guy who asked me for more than I could give him. I seem to remember a book by Bridges or something like that where the projects in the book were intended to be accomplished by hand tool usage. This type of article sets up a little easier for a beginner, I am thinking????? other than him having to figure out what to use instead of a hollow chisel mortiser or a biscuit joiner???
Ron ... who used his Langdon Miter box Sunday to build three tables and only used power to drive screws... Yes I know, have driven them with a brace too .. but not this time.
That's exactly it!
roninKokomo
>Thanks Bob
That is exactly the kind of think I think my friend needs. Know where I can find any more articles like your post?
Ron
Yes
roninKokomo
>See my note below. The article that Bob just re posted is the kind of thing that would help this beginner friend of mine.
Re: That's exactly it!
Bob Rozaieski
>Send me your email address. I have some old Dunbar articles in .PDF format I can send you for him/her.
paul womack
>Just use 1930's UK books!
e.g. Jones, Bernard E, "The Practical Woodworker" (I don't know if the reprint covers the whole 4 volume original), or Hasluck's handyman book.
BugBear
Re: That's exactly it! - Roy
ThomD
>Possible the single greatest repository of do it yourself handwork is in the Woodwright books and videos. The videos are online for a few years worth. Notwitstanding the limits of Roy's real time recording requirement, he has given enough info to complete a lot of projects from simple ones like saw horses and benches to more demanding ones. In most instances he doesn't provide dimensions though few years back he did a series of projects that had most of the dimensions included.
One that should stand as a template for the work of others, is the Chair book done by Drew Langsner. This one is soup to nuts and has sidebars on how to build the stove. Nothing even close to it. For those of us who do other crafts that have blow by blow books, like fly tying, this is the kind of book we have been missing in woodworking. On the other hand you have to want to make chairs...
There are two excellent books on Shoji...
While it may seem a stretch, I believe the more technical Krenov books fall into this catagory. For those who want to do their own design this is the how to book. Not all handtools, but that brings us to...
Hand tool projects are not all that different than regular projects. You have stages like stock prep, that require special tools like benches and appropriate planes. You have various joints like butts dovetails and mortise and tenon joints that require specific skills, You can add or subtract these steps from any project, once they have been learned.
DUH!! ST. ROY... OF COURSE
roninkokomo
Thanks
roninkokomo
Re: ST. ROY... new book!
ThomD
>I'm always the last to know - new book in October.
One of the interesting things about hand tools
>today is how much common knowledge is lost.
As I've mentioned before, I've been reading through LV's reprints of the Popular Mechanics Shop Notes from the first part of last century. I am continuously intrigued by how many things are incomprehensible to me because I don't have the common knowledge that the writers assumed EVERYone had about certain processes (I had to learn what a fuller ball* was from my son, who somehow soaks up this historical knowledge from the ether). I think the same thing's true now with hand tools. Separating the project made with hand tools from the techniques necessary to make it with hand tools, when not everyone grows up seeing Dad or Mom using them, can be tricky. I find this issue sometimes with older books that are supposedly written for the beginner - the author assumes too much about what the common person will know.
So I don't think people intended to insult you, Ron.
I'm glad, though, that the collective thoughts of the group brought up some good resources.
*For those don't know either, one of the early faucet designs used a hollow rubber ball ("fuller ball") that was supposed to close off the water flow when it was compressed, and permit it when it was lifted off the seat. The design didn't last long, apparently, because they wore out quickly and leaked with great enthusiasm; but they were a godsend for the clever handyperson who needed a hollow rubber ball with a hole on each side that could be found, cheap, in the hardware store.
Thanks
roninkokomo
>I guess my post sounded a little more testy than I meant it to. I was just trying to help out a beginner and I couldn't remember some of the resources that I certainly knew about. I appreciate the memory refreshers.
I don't use plans much myself anymore, or rather I should say that I try to do my own designs. Obviously frought with the opportunities for major screw-ups. DAMHIKT
Ron
