Did I just buy turning saw blades?
>Went out for a very little garage sale cruising this morning - going to be just one, but I heard at that one (which yielded just a very imperfect perfect handle screwdriver and a C-clamp) about another nearby with "some old tools." When I got there, I found a mixed bag, but came away with four sawblades 3/8" wide, with holes in the ends (some with pins, some without), a little over 22" hole to hole, what look like crosscut teeth in 11 or 13 tpi. Did I just buy the beginning of another project - a turning saw? Or are these for some other purpose?
Also a 12" Brown and Sharpe No. 4 rule (been looking for ages), a leg vise screw and nut, what looks like a replacement blade for a Nobex-type miter saw (basis for a Tage Frid-type frame saw?) and a couple of other items, $5 the lot.
Re: Did I just buy turning saw blades?
Chuck Nickerson
>With a blade width of 3/8", unless the tooth set is quite wide, they are 'sort of' turning blades. The Gramercy (TFWW) bow saw blades come in at 1/8". Now that's a turning saw blade (IMHO). The same issues apply here as with bandsaw blades.
Nice score Bill!
Scott Burr in Ben Lomond, CA
>At 3/8" I feel their to wide for turning applications. You can cut large curves 3" of greater with a blade that size.
You going to re-handle that screwdriver?
