Interesting bits on my new Stanley 20
>The Stanley 20 sole and the part one grips (call this part the body, for lack of a better term) are separated parts, linked only by the adjusting screw and two links, fore and aft. Before holding one in my hands, I'd kind of assumed that one of these links was more or less rigid, with the other pivoting to accommodate the change in length of the sole as it flexed. But they both pivot, and are kind of flimsy affairs, about 1/16" thick, pivoting on rather small pins.
I spent some time looking at it, pondering what kept the sole from being driven backwards relative to the body by the force of planing. Then I realized that it's the central adjusting screw, which is firmly fastened to the casting on which the frog attaches, that locates the sole. The adjusting screw passes through a thick cast portion of the body, which bridges from one side to the other. Coolest part: the Stanley elves made the screw threads flat-topped, with even less "minor diameter" portion than an Acme thread, so that they won't get bunged up by their contact with the casting.
The top and bottom castings are offset enough to permit maximum concave deflection of the sole while maximizing depth up the upper casting, I presume to maximize the rigidity of the construction.
They also used a 1-3/4" iron, to reduce the forces involved.
Even so, I would not want to hit a knot with this tool, or try to hog out a shape - definitely a smoothing plane only.
Bill, always intrigued by the ingenuity of those guys.
