Smallest Perfect Handle Screwdriver
scott grandstaff
scott grandstaff
>Hi
I made this today.
My friend Wayne gave it to me. It was the smallest regular size already but was broken off short in the shank and generally in bad shape.
It wa forged and ground and fitted with brazillian rosewood.
The middle driver is a normal 6". The top is the smallest regular size that I fixed up and filled with ebony, you may remember.
The new one is on the bottom.
Ain't so much maybe, but it's the only one there is or ever was.
yours, Scott
Re: Smallest Perfect Handle Screwdriver
Sweeeet!
Rob Brophy...lost in Niagara
>Nice work Scott!! The proportions are perfect...one would never know it didn't leave the factory like that (except for the flawless polish and exotic infill :-) ) Well done.
How about a few more restoration/reshaping details?
steve mackay
>Man, those are too cool for school ! You've created a real treasure ! I know a lot of folks are of the "if it works, its good enough" school but I'm in the "if its beautiful, its more of a thrill to use" school. I'll bet you get a smile every time you pick one of those up !
Very nice!
Chuck Nickerson
>I recently purchased the ugly set offered by Garrett-Wade, hoping I could make them nice. I'm deciding that perhaps I don't have the patience for rehabbing tools.
scott grandstaff
Smallest Perfect Handle Screwdriver *LINK*
scott grandstaff
>Thanks Guys
It was kind of weird actually. I wasn't all that sure it was going to work. The shaft was broken off real stubby. That's why the forging.
I grabbed a pair of vise grips and aimed 2 propane torches at each other and lit them up. 2 torches works a -whole- lot better than one alone ;-)
First I pounded the tip straight down to full it up then went to thinning and lengthening the shaft using the bolster below the handle as my stock.
It's so little I got maybe 3 hits at red heat before it went cold again. So there were a lot of swings back and forth between the heat and the anvil. Didn't take long to heat back up at least.
When I got it long enough again I flattened the spade end.
There was a lot of grinding to reduce the top and sides of the frame until it proportional again, but then look at the size of it, how much grinding could there really be? It was mostly slow and careful grinding. Take a little off and look from all sides. Take a little more, and on like that.
Files came last. Same thing. Cut a little, look a little.
When I was satisfied, there was one more heat up to bright cherry red all over and plunk down in an oilcan of oil. I just took the top off my regular pump oiler for this job so I didn't have to mess around. heh It won't hurt the oil any. (with a small plank of wood handy to smother the fire)
A quick rub with a piece of 100 grit sandpaper gave me some shiny metal to see temper colors and I slowly heated the frame until I got a nice deep overall blue leaving the tip out of the flame and quenching when it went to brownish/purple.
You want spring temper in a screwdriver except at the very tip. You want that harder but not a lot. Purple brown is the color just before blue.
The handles were fit in the customary manner. The story is on my webpage, has been for years.
( Check it out, but then most of probably have at one time or other. I need to update that page something awful. It's so far behind now it's pretty embarassing if you knew. )
An assortment of grinding and polishing tricks finishes the job.
Grinders, sanders, hand sanding, polishing both coarse and fine.
Same as you would do with any tool.
It really isn't hard. None of it is. Takes some practice and you have to think on your feet and watch what you're doing.
But if you care and you want to do it, it's all possible.
I get off on new design on the old standards. You would think every idea possible was already done in the field of tools after thousands of years, but I'm here to tell you, there is always room at the top!
I have to say, I took it to town in my pocket yesterday afternoon. The girls were crazy for it. The girls at the bank and the ladies at the PO and grocery store too. They all wanted it bad! (nice to be wanted :-) Oh wait, it was only my screwdriver they wanted. hee heee)
A very small yet highly refined and polished screwdriver looks like it would sell around 400 million copies in a year if you could get them to a wide enough market.
I'm just the idea guy though.
yours Scott
Original Design Tools
Very nice Scott!
Scott Burr in Ben Lomond, CA
>Maybe the next time you could post some info for us daft ones. Mostly how to rivet the with a bit more info and some additional pics. I still wonder how doesn't dent the wood during the process...
scott grandstaff
Very nice Scott!
scott grandstaff
>Thanks Scott
The handle instructiions are on my page under Perfect Handle awl. They've been there for years. I've taught lots of guys to do it. My old friend Jim Thompson did a tutorial and it's over at Wikor's place and I think Roy(Griggs) has one up someplace too.
You aren't going to crank out 20 refitted Perfect Handles a day (tried that) but with a little practice it can be done and nicely.
So long as you doing wood that is.
I have one I'm stuffing with mother of pearl and Wayne (Anderson) did one in ivory last year. You don't get to cheat and squeeze the handle in with hard material. It's a different ballgame.
But everybody can do wood if they want to. Try it!
yours Scott
Thanks Scott!
