reusing cedar decking
Patrick Wheatley
>Hi All,
In my efforts to keep wood from the land fill I was wondering if it is safe to reuse the cedar 2x6's that I am taking off my deck. They are about 20 odd years old and some of them are rotten and will have to go, but, some are still pretty sold.
I was thinking of dimensioning them to remove the outer wood (and old stain/paint the previous owner put on) and using the solid cores as drawer bottoms. Is this a good idea? Do I have to worry about bugs and other nasties getting into my underwear drawer?
If I can't user the salvaged wood for drawer bottoms I will find a use, my wife wants planters and I am sure they will work well for that.
Any advice would be great.
Pat
Re: reusing cedar decking
Bill Schoenbeck
>Not Cedar but redwood in my case. We had built a deck many years ago and in 2003 I dis-assembled it to make room for an addition on that side of the house. I stored the wood and used for many projects over the years. Picture frames, boxes, an outdoor cooking cart for my wife. I even built my workbench out of it. 4x4 redwood legs, 2x6 frame and 2x4 redwood lumber glued on the wide faces for a thick sturdy workbench top that is surprising resiliient to dings.
Some of the wood had termites and other insect damage. That went into the dumpster of course. But most of it was in good shape. I'm now down to the last of it. Just a few 2x4's and some 4x6's left. I love to re-use things. Go for it.
Bill
Jack Guzman from Maine
>Recycled wood is great to use for projects.The wood has had plenty of time to stabilize.I had a pile of 3/4" cedar decking laying on the ground for over ten years.When I finally got aroung to cleaning it up there was a little rot but not much.After cleaning off the dirt and planing off the outer layer I got some nice stock to build a rose trellis for the yard.---Jack
BobStrawn
>I make planters out of it. Planters don't have to be load bearing. I will try and take a few photos of how I do it and post them later, nice and easy really. Some cedar is phytotoxic, so this could be a very bad idea. The cedar I get has been fine, but then it is usually juniper. Most cedar is no cedar. Some cedar is hardwood, most is softwood. Go figure, if it looks kind of like cedar and is aromatic like cedar, then we call it cedar.
Bob
I would be concerned...
>about any grit that is imbedded in the wood from being a deck. I would imagine that it would dull the hand tools quickly.
Stephen
Re: I would be concerned...
ThomD
>Often the wood used in decks is of super high quality. Really a sin that so much redwood and cedar were wasted on such cheap and short term uses when much of it was spar or instrument grade wood we won't see again.
Leaving out damaged stuff, structurally the reuse depends on how heavily the wood was deflected in use. If adequate joist were used then the wood does not deflect significantly and it retains it's structural qualities. Obviously that isn't a concern in the uses mentioned anyway.
James Watriss
>The main thing is finding a good/safe way to clear away the crap that's collected on the outside. Paint, grit, etc... Wood dust is bad enough, I wouldn't want to huff paint dust, even by accident.
Hand tools are one way to do that, provided you're using a beater plane or beater iron. (scrub or jack plane, maybe?) Or, if you have a jointer/planer, you could try those, but be sure to wear a respirator. I think my personal preference would be a belt sander in the driveway, or a drum sander or something like that.
Patrick Wheatley
>Hi Guys,
Thanks for all the information. I am glad there were no warning about little animals getting into my undies while i sleep!
I was planning on using hand tools to remove the paint\stain but i also have a power sander that i bought used and have never used so that might be the best option before putting the wood through the other operations.
Thanks for all the info. Until the next time i am stumped.
Pat in rainy Montreal
Re: What? you want the real answer?
ThomD
>I wouldn't say you can't have an infestation, I mostly didn't coment on it because it would depend on more info than I have.
First is the fact that other source "factory" wood is not imune to infestation, even if it was kill dried, it can spend a lot of time out of doors loafing around before you buy it.
Your main defence is that you will get to examine the wood carefully while you work it. And cedar is resistant to pests. The thing that would worry one the most is the presence of nail damage that is simply difficult to inspect. maybe these could be cut out and plugged, or cut around.
Do you have a lot of insect or rot damage in the structure, though even then, what happens in one piece may not migrate to another, particularly if you had, say, pressure treated post and cedar decking, then the conditions for life are totally different. In the old days when wood was harvested from the forest directly, it wasn't unusual to find mixtures of species in the house. On disassembly the rot and insect damage can be very specific to individual pieces.
That raises another point, mostly theoretical for me. Most of the spcies around here are not going to be all that tragic, you do have to factor in whether you have the risc of bringing into the home something really terrifying. There are termites, and there are termites, but if you live in a reasonable environment without a lot of invassive super species, I wouldn't worry.
One thing that did provoke my spiddie senses was the fact that this structure was painted. That is unusual with cedar, because it doesn't always take paint well, and it does not need it. Paint can cause problems by differentially holding water in or letting it in. It also makes me wonder how good the underlying wood is. There are also serious environmental issues to removing paint. Such as you wouldn't want to sand away a ton of lead paint in order to salvage a few bucks of wood. While lead is an obvious issue other paints have largely undisclosed junk in them. With thick material where faces could be bandsawn away with good dust collection to good filters... There are also risks to rot, if you have to process that too.
Paint and toxics aside, if you can end up with stuff that looks like "factory wood" that is usually good enough for me.
Patrick Wheatley
>Well you do have some good points.
The paint on the decking was also a mystery to me. I assumed when we bought the house that the deck was PT wood which is why they painted it. I am replacing the deck because there are some rotting planks with a lot of peeling paint plus after 20 odd years the joists under the deck are becoming suspect.
When i cut away at a couple of the planks the smell of cedar was obvious imediatly which made my wonder why they painted the deck in the first place.
I was thinking about using a circular saw to cut away the sides and then using a bandsaw to remove the face. Unfortunately it is not my bandsaw and i would have to truck the wood to a shop where i rent tool time and i am not sure if they would appreciate me cutting up old cedar decking on their machines. I also wonder what my wife would say if i started power sanding in the drive way, it is sure to make a mess.
I will have to take another look at this as i remove the planks.
Pat
Hey Pat don't be fooled by Thoms post...
Scott Burr in Ben Lomond, CA
>Clear and clean your old wood. If you see bug holes or damage in a week or two don't use the wood. It's all common sense. Saw it up and use it after you wait a week or two. Don't worry too much you won't be puttin' crab's in your drawers.
Re: The end of the world is neigh.
ThomD
>That is more or less what I said. OK less. When you are working this stuff by hand you get adaquate time to look it over. Though in my area not much bad would happen no mater what. We don't have those formosan termites or whatever they are called. Though just because it is in your deck doesn't mean it is worth the trouble of reusing it. To each his own. There is a lot of great wood on the 125 acres I am on and a lot of it is too much dang work.
Speaking of which, the tree just outside our house was struck by lightning. It is a huge ash with 20 or a lot more inches in the trunk. I was closing a window at the time and saw what looked like a rack of 2x4s blow (as in dynamite) down the beach to the water's edge. the grain is spiral twisted a little and other racks of 2x4s blew up the field and all over the place. Nothing came back to the house so in a sense we were lucky. Does give you a new set of data points for that lovely tree you have just outside your bedroom window... I think a person might have been killed had they been standing in the way of the ground level stuff. Percent wise not much wood was blown out of the trunk and I would guess the tree could survive though a lot of damage ocured in branches above. If it has to come down, that trunk is going to hold a lot of ash. Whether it is worth going after is another mater. Any arborists want to see a picture to guess what the survival potential is.
Re: Hey Pat don't be fooled by Thoms post...
Patrick Wheatley
>Actually, I am not as concerned about the little bugs as I am about the paint and dust I will create from getting it off. Is it worth the mess and potential health risks to power sand or plane off.
Once I get the boards up and am able to inspect them a little better I will know more.
The demolition continues this weekend unless it keeps raining. In which case I will be inside working on my chest of drawers. I am still getting the courage up to cut the pins in the side of the case.
Wear a mask and eye protection or/and...
>Use a chemical stripper to remove the old finish(es). This is when you could go rent a power planer, get the insurance on it and run them through it. This will dull the planer blades, hence the insurance so you don't have to pay for the sharpening.
