Re: Rehandling the chisels
Wiley Horne--So. Calif
>Mike,
Interesting point about burning in. This is a typical way of setting a Japanese saw tang in its handle. But I have not heard of this being done with chisels. I'm not an expert at all, so it may be that burning in is sometimes done, but I am sure that a straight friction fit will work.
If you look back at So's site, notice that the chisel tangs are square in section. What the handle fitter does (the handle guy is a different guy than the smith) is drill a round hole for the square tang--the square corners of the tang will then bite into and compress the handle wood. How much clearance he provides will depend on the hardness of the wood species--it would be different for kashi (Japanese white oak, a live oak) than for ebony or one of the rosewoods. You might make a dry run on a piece of the maple scrap and perfect the technique there before drilling your handle pieces. You need to know how much pressure your wood will take before it splits.
Of course, the tangs on your chisels may have a different shape than the japanese tangs. Maybe Woodcraft knows, but more likely you're gonna find out what you have only when you get the handle off, and look at it.
Now If you have a friction fit (as opposed to glue), you should be able to loosen the handle simply by holding the chisel by the blade, and slapping the full length of the chisel down onto a block of wood, or bench. Do that a few times and you should be able to pull the blade apart from the handle with your hands, or with a little assistance from a wooden vise. Note that the handle will not _turn_ if the shank is square, so the pulling has to be directly parallel with the axis of the chisel.
Am pretty sure this is obvious to you, but make the new handles a bit long, because when you start the fitting, if the handle taper turns out to be a bit overdone, and the fit loose, then you'll need to cut a bit off the small end of the taper, and work the taper up higher on your handle blank. Do the fitting before you cut to final length.
To set the new handle, just put the chisel edge onto a piece of wood, and tap the handle with ferrule down over the tang with a mallet. If it closes to within, say, 1/8", and feels right, then hammer it home.
Wiley
