OT - boot stretching
>For the last couple of days, I've been in work boots all day, and my right big toe's been killing me. I realized today that somehow, an inner part of the boot is folded down (not steel toes on the boot, just leather), pressing on the toe.
I can buy new boots (these were over $100!) or go to a shoe shop, but this community's got so much knowledge. Any idea how I can stretch it out?
Bill, back in sneakers for a run to the store, and feeling good.
Re: OT - boot stretching
Ray Binnicker
>Bill,
When I was in the Army and got a new pair of boots (the black leather junp boot) I would put them on, stand in a pail of water (6 to 8 inches deep) and get them soaking wet. Then I would wear them the rest of the day until they dried out. I was a lot younger then and maby a lot more tolerant of sore feet, but it always seemed to work.
Ray Binnicker
ThomD
>idealy stretching should be done dry, wetting leather will make it more pliable, but it can cause a number of other changes that aren't desired, and it remains possible that the toe will not have the side pressure to expand the leather anyway. A better shoe or hiking store should have a hydraulic stretcher that uses specially designed jaws to expand the leather. In the absence of access to such a machine I normally shape a piece of wood and force it into position or use an appropriate found object.
Bill Tindall, E.TN
>We have a local shoe person that is 80+ years old. He has a set of shoe stretchers. There is procedure where he "wets" the shoe with something and then puts this foot-shaped stretcher in and leaves it there a day or more till the wetting stuff evaporates. He can expand a shoe 1/2 size.
I would think that this procedure would fix your problem. Now to find some 80+ year old repair person that has the equipment and experience to do it.
goodolboy
>2 more possible ways for you to get-r-done.
There's a product sold commercially just for this sort of problem, and I'll bet that's what the cobbler was using. I believe that my wife still has a spray can of it around here somewhere, but I can't put my hands on it right now, or I'd give you an exact name, but I THINK it's called Shoe Stretch. It's sold in many "odds and ends" household goods mail order catalogues and also in some variety stores in the section where they sell shoe laces and other footware products. (maybe even at Wally World)
Next up is the real deal. There's a fairly inexpensive special purpose-designed tool that looks like a medieval torture device, which is made precisely for this job. Shoemaker's have them, as mentioned by someone else. Tool junkie that I am, we actually have one here. (I like having weird tools around, sometimes just to puzzle my friends, what can I say?)
Anyway, they turn up on eBay fairly regularly, and look like a very long thin pattern pliers, with a hoop or ring on the extreme end of one jaw, and about a 3/4" dia. ball on the opposing jaw. The ball and ring are sized so that the ball goes only partway into the ring.
The jaws are long enough from the pivot down, to be able to get down to the tips of MOST shoes/boots, and they aren't as long as you'd imagine, because you have to be able to bend even most solid shaft type boots to be able get your feet into them. The handles sometimes have a loop or chain from one to the other to hold them togetherwhen they are applying pressure, so they don't have to be clamped in place.
The stretching is done as someone already mentioned, but if you actually go so far as to try to locate one of these neat looking pliers, I'd try to use something to at least soften the leather a bit in conjunction with that, and leave the pliers on overnight if possible. You can actually stretch and thin the leather too far and even tear it if it's too dry or too brittle or you're not careful, so go slow.
Even going through all that sure beats what Indian women used to do with moccasins and most leather that was worn against the body-chewing on the leather to help soften it.
steve mackay
>I've go a shop where the owner is a cobbler not just a salesman. I've got a BIG bunion on the big toe and would need the next size up ( 15 ! ) to accomidate it. My dude streaches 14s for me and all is well. I think its alchemy ! I also used to do the thing with combat boots in water but don't think I could handle it now. The feet need to be stronger than the leather and I know mine ain't !
Buy a bigger pair of boots
Dale Lenz
Re: Never have tried it...
Dale Lenz
>myself, but the leather softer that Google uses to stretch leather is rubbing alcohol and water, 1/3~1/2 alcohol mixed in a spray bottle.
Dale Lenz
Re: OT Come to think of it...
Dale Lenz
>I had a corn/bunion form on my the outside of my little toe. Some how my boot formed a small dimple in that area. I tried pounding a piece of wood in my boot, did not work, should have(?). Purchased a 10 dollar(?) wooden shoe/boot stretcher with bunion buttons. Poured water in my boot for maybe 30 minutes(?). Put the stretcher in boot with bunion button in correct spot and stretch away. Left stretcher in place until dry, one day(?). My little toe loved it! An alternative would be to take your boots to a shoe shop and have them do the same thing.
$ 140.00 vs $ 220.00 . . .
steve mackay
>and a sloppy fit. I'm just carefull about my rat chasers.
