THE WOODRAT IS BACK!
cannel chisels
cannel chisels
cannel chisels
peter kolb
>Hi, What is the difference between a in and a out cannel chisel. Thanks for your help Peter in south central NJ
Re: cannel chisels
Re: cannel chisels
Wiley Horne--So. Calif
>Hello Peter,
An outcannel chisel, generally called an outcannel gouge, is the familiar carving gouge. The bevel is on the outside. If you go shopping for a carving gouge, it'll be outcannel. Chisel is the more inclusive term; a gouge is a type of chisel which comes in various sweeps or curvatures.
An incannel gouge is often called a patternmaker's gouge. The bevel is on the inside. See here, for example:
http://www.dastrausa.com/PatternMakerToolLine.htm
Lots more could be said about gouges, especially the less familiar incannel or patternmaker's gouges. Sometimes I've seen them called scribing gouges.
Wiley
Re: cannel chisels
Re: cannel chisels
Pam Niedermayer, Austin, TX
>What Wiley said, plus many carvers put a smaller bevel on the opposite side of the main bevel; so they often use chisels with both in- and out-cannel, sort of like knives.
Pam
Re: cannel chisels
Re: cannel chisels
peter kolb
>Thank you Pam and Wiley Peter
