Have a question? Ask Woody!
block plane identification help-please
goodolboy
>(this is why I canme to the site, but I got sidetracked)
A friend of mine gave me a plane the other day, and I thought that I knew what it was from his description, but when it showed up, I was and still am a little stumped. Maybe someone can help though this site?
I originally had thought that it was a typical low angle, adjustable mouth Stanley #65 block plane, from the approximate size and general configuration of his description, but that was before I looked at and started measuring.
This is a long and well used plane, from the hand wear to the casting and cap, and the shortness of the iron, and it's not been abused, but definitely not a show piece. I'm just curious if anyone else has seen one like this.
I'd send photo links if I could, but I don't have that capability, so I'll describe it as best I can.
The body is either cast iron or steel, fine grained and smoothly cast, with very minimal pitting to the unpainted areas.
The sole is 1-15/16" x 7".
It has about 70% of it's japaning.
The original rear adjuster knob has been either partially lost or replaced with a brass piece that has a small diameter threaded hole on the outboard end-(which could possiblyhave originally received a larger diameter knob than what is obviously not complete but still in place).
The iron/steel cap appears to be nickel plated, although most is missing from the rounded heel.
The blade lock is beneath the cap and swings behind the cap, tightening towards the user.
The iron itself is 1-9/16" wide x 3-5/8" L, (barely reaching the end of the cap), it's marked OHIO Tool Company, and has 5 round original adjustment holes, with one additional hole drilled by a prior user. It is bedded at a low angle.
The iron side swing angle and iron advancement adjuster is consistent with the Stanley low angle adjusters that I've seen on some low angle Stanley block planes.
The plane's mouth is adjustable, and the sliding piece appears to be consistent with the Stanley style, both the knob and it's mounting boss are also consistent. The sliding piece also has what appears to be a factory original stamped-in "65" on it's hidden upper surface.
Here's the problem:
There are no places on this plane body with a maker's name or number showing. Nothing either stamped or cast-in from the maker
AND
This plane body has what appears to be original, slightly recessed, 1" diameter ROUND finger grips milled (one per side) into the sides, centered fore and aft on the plane body, instead of the typical Stanley's OVAL or NO finger grips.
Does anyone know if this one is actually a Stanley produced plane, but one possibly made for the OHIO Tool Company (as the iron is marked), for someone else, with only an OHIO iron, or an unauthorized backwards-engineered one from some completely other tool maker?
thanks
Re: block plane identification help-please
Neal in San Jose
>It sounds like an Ohio Tool produced plane with a problem or two. I don't have my Ohio catalogue with me at work so I can't give you the model number, but it would be the same as a Stanley, except with an "O" in front of it. I've seen Ohio planes with the round machined recess in the side as you are describing and have a couple of Ohios that have no name anywhere except on the blade. I'm having difficulty visualizing the blade adjusting mechanism; too bad you can't post a picture. They went out of business around 1916, so obviously the plane dates from before then. It probably won't sell at a premium over a similar Stanley. Ohio Tool's quality varied significantly over the years, and frequently was slightly lower than a similar year Stanley, except the blades in their bench planes were pretty nicely laminated and tapered. Even some of their block planes, like yours, had laminated and tapered blades, but it may be pretty hard to tell if it has been used up as you describe.
Ohio copied Stanley pretty shamelessly, often infringing on patents or making really minor changes in an attempt to navigate around Stanley's patents. There are lots of legal cases of Stanley and Ohio suing each other you can look up on line if you get REALLY bored. HTH
goodolboy
>Thanks for the information. If you happen to get a chance and have a camera, would you mind sending me a photo from the Ohio tool catalogue that you have, if it has a picture or drawing of their version of the Stanley 65? I think that's the model number of the one that seems to come closest to this low angled one in size, although Stanley's is actually a good bit narrower, from what I've been reading. thanks
it's goodolboydws@bellsouth.net
