Re: Hi James, Are you talking about...
>The glass is probably held with points prior to the application of putty. A traditional formula is whiting (calcium carbonate) and linseed oil made to the consistency of putty. It is a good idea to make it kind of dry and a bit crumbly to work better with the knife.
You can also add a bit of oil based varnish to the mix to help with drying or you can use white lead to speed up the process at some risk. If you can get a good glazing compound that is not an acrylic or other synthetic base, that is preferred.
The advantage of putty is that you can keep at it until you get it right, the corners are the trick.
Stephen
