Re: Speaking of cambering
>Hi Wilbur
I am not enamored with a machine creating a camber on a blade. I recall David Charlesworth mentioning that he sometimes uses the loose blade holder on his Tormek to do so.
I do not like the machine for a camber simply because each blade is a little different - the bevel edge is wider, thicker, thinner, harder steel, softer steel - and the camber needs to be developed for each. This may sound pedantic, but in practice it takes no extra time at all, just a little extra thought.
Whether I use a Tormek for a hollow grind or a belt sander for a flat grind, the next step is to follow up with waterstones, in my case Shaptons.
My method is a modified version of David Charlesworth's "honing by numbers" (my name for it). The camber is created on the 1000 grit waterstone. The remaining stones are there to polish the edge.
1. With the 1000 stone, hone a straight bevel and stop once you have a decent wire edge. Standard stuff.
2. Now remove the wire edge on your final polishing stone. This may be a 8000 or 12000. I know that some prefer to remove the wire edge at the end - in fact it should diminish in size with each successive polishing stone. However by removing the wire edge you are better able to determine the progress of the next step. I remove the wire edge at the completion of every stone.
3. Placing pressure on one side of the bevel, pull the blade back. Count the number of strokes it takes to create the wire edge size you want. This will equal the amount of camber created. Do the same on the other side of the blade. That is, hone the same number of strokes on that side. Again remove the wire edge.
4. Now progress to the polishing stones. I go 5000, 8000, and sometimes 12000. These are not going to remove much metal, less with each finer grit, and this is the reason the camber was created on the 1000 stone.
5. I continue to count the number of strokes taken on each side since I want to make sure that the camber is symmetrical. The essential element, however, is that you remove all the scratches of the previous grit before moving to the next stone. On average this may only require 5 or 6 strokes on each side - but this does depend on the size (thickness) of the secondary bevel.
Hope this helps.
