window glazing
window glazing
Jack Guzman from Maine
window glazing
>I just recently built some arched sashes for a project.The finished window will be three sets of sashes with the center one taller than the sides. I just started cutting the glass for the arched sections and I came to the question I always have when glazing and never seem to get a clear answer.
What's the proper way to prep the bare wood before glazing? I,ve seen written that you should prime the wood first.This makes sense but will water based primers or shellac based work or should you always prime with oil based? I've had old timers tell me to apply linseed oil. Should you use raw linseed oil or will BLO work? I always use the glazing compound that comes in a can at the hardware store.
So does anyone have any definitive information on this subject?
Meanwhile,I just keep trying this and that and look for a difference in the results.All I really know is not to leave the wood bare.
thanks,
jack
Re: window glazing
Re: window glazing
Larry Williams
>Jack,
Linseed oils supports fungal growth, I wouldn't use it on window sash or jambs. Use what ever primer matches the paint you intend to use. A shellac primer wouldn't be a bad choice because of its moisture resistance.
Re: window glazing
Re: window glazing
>Not sure that the modern window glazing is oil-based, as the old was - which, I think, was why priming the rabbet with oil was important, so that the bare wood would not soak up the oil and cause the putty to dry out before adhering.
I'd be inclined to agree that priming with whatever you're using otherwise makes most sense, but then, what would I know? The only cabinet glass I've installed is held in place by wood strips.
Re: window glazing
Re: window glazing
John Todd
>Most any primer will work. You just need to see the wood so that it doesn't soak the oil out of the glazing compound... that makes it brittle, then it cracks and falls out!
Re: window glazing
Re: window glazing
>Thanks Larry,I didn't know that about linseed oil.---Jack
Re: window glazing
Re: window glazing
>Bill I do believe it is oil based.At least it smells and feels like it. I do alot of glazing. Mostly old window repair.---Jack
Re: window glazing
Re: window glazing
>Thanks John,
That is what I thought. I guess it's just considered common knowledge because I haven't seen it written in any of the woodworking books I have read.---Jack
