Why you want saw teeth at the end of the blade
Scott Burr in Ben Lomond, CA
>So you can saw things like this. Pretty much impossible to do with a saw that is toothless at the front of the blade.
Ha Ha!
Bill Tindall, E.TN
>What are all those X marks?!? You don't forget which side of the line to saw........ ever?
(PS, you should see my pieces. After doing it once (oops, well maybe twice) there is no limit to the marks I make
Re: Why you want saw teeth at the end of the blade
Dean J in MN
>Huh, I cut the half blind from the lip toward the center of the drawer, reverse of how you are cutting in the pic. You could get away with no teeth on the tip of the saw that way.
-Dean
Paul Kierstead
>Well, ya know, it ok to own more then one saw. How many more? Well, uh ..
Just what I was going to say
>spent a whole 50 cents on a late model Disston that I hardly need - think I'm up to 20 saws or so, which I know makes me a beginner.
Marv....... Northern California Lake Co.
>Scott,
That saw looks a bit dull....
Doesn't everyone have more than one saw?
Marv
Yep, I've cut enough
>Martian DT to have learned my lesson now.
Yes, you could Dean...
>I find by doing them this way I can get a deeper cut with out over cutting into the drawer front. By the time I'm dome cutting this way the saw is almost vertical and there is very little to remove with a chisel or the tapping of the kinda dull scraper method.
Yes it is...
>A bit dull Marv. Now that I'm done with the drawers, it's going to be taking a little time off and go a bit north of me for some R&R (rest and rehab). 8^)
Re: Yes, you could Dean...
Dean J in MN
>Ah - I see.
I just overcut into the drawer fronts.
-Dean
