Wild West Handsaw - 2 Handles Back Saw
charlie belden
>(So as not to get accused of being a shill for
Glen-Drake tools, let me state up front that
I have NO association with Glen-Drake or ANY
reseller of Glen-Drake tools. I own, and paid
list price for, a Glen-Drake Tite-Mark and
have found it to be a very good, and very
versatile marking - and measuring tool)
The July-August issue of Woodworker West has an article by Kevin Glen-Drake entitled An Alternative Approach for Hand Tool Joinery. The article suggests learning to cut BIG simple box/finger joints in THICK stock. The premise is "if you can't see it you can't figure out how to fix it". (sounds paradoxical but it does sort of make sense).
Anyway - three photos in the article show him using a two parallel handles back saw to cut most of the joints. Looking down on the top of the saw, think wishbone ( Y ). The text calls it the Wild West Saw (TM) and, in addition to the two parallel handles, which allows you to stand shoulders parallel to the part being cut, looking striaght down over the blade, the saw blade itself is different. The first and last inch or so has no teeth.
The "no teeth front and back" seems like another paradox. If you've made a saw blade, why no teeth front and back?
So I read on and found "Kerf Starter" (TM) - what looks like one of those short handled, short curved blade wittling/carving knives - but in fact has a thicker blade, no bevel(s) and acts as a scraper. cutting a shallow line - the width of the saw blade's kerf. The result is a shallow, square sided, flat bottomed "line" in which the saw can be set.
Since this is a handtools forum, and most here have used various handsaws, it's the start of the cut that determines how well the rest of the cut will go - regardless of whether you're using a push or pull saw. Normally the cut is started using your thumbnail to register the far end of the blade to the line (or just off it on the waste side) while you eyeball the blades position over the line at the back - and try and keep the blade from tilting left or right, seeing only the side closest to you. And then a little pulling back before making the first push stroke.
When you think about it, it's kind of like walking and chewing gum while humming and maybe juggling. Seems simple, 'til you've screwed up a dozen or two cuts. With practice and a bit of figuring out what went wrong and how to adjust for that, muscle memory takes care of things and the cuts get better and better. And if you use a saw regularly it becomes an automatic thing.
BUT - if you DON'T use a saw regularly . . .
This "system" seems to solve several common problems with sawing accurately.
- the wishbone arrangement, with parallel saw handles puts an eye on eithe side of the blade, a slight tilt of the head to see each side of the blade where it meets the wood
- by standing with your shoulders parallel tothe face of the part to be sawn, you can see if you're leaning the saw left or right
- by starting the cut with the toothless part of the blade in the shallow, square sides, "scribe line" you've got the blade registered and can create some foreward momentum BEFORE the teeth contact the wood and the same goes for the back stroke.
- the way the handles are set, you "steer" with your thumbs, not your wrist - which seems like it'd provide better control, though that would probably involve some mental and physical adjustments.
In theory, this saw and "kerf- starter" seem like an innovative improvement to hand sawing. Anyone with any experience with the Wild West Saw? Likes, dislikes, comments?
charlie belden
