Veritas - Innovation in Tools
need practice sawing dovetails.....?
Bill Tindall, E.TN
>.....build a trunk. I'm getting plenty (and needing every hour of it). 17 feet of dovetail sawing in this trunk I am building. Wrist is sore and saw dull. If I was doing oak trunks for a living I would be buying a bigger heaver saw than the LN dovetail saw. The piece in the PIC is the back panel.
I do a mix of hand and machine work, as well as use the bench for "farm repairs". So the bench is just a big flat surface with vices on the corners. I get around not having the fixtures of a traditional bench by use of clamps. The 2 x 2 clamped to the bench provides support for the piece being sawed. I have problems hitting the back scribe line so I find it faster to used a crutch. I clamp a stick to the back along the scribe line. When I have sawed to it I know the back is right on the line. The 200 foot candles of light I have at bench height comes in handy for following the pen line. I mark with a gel pen. It shows up vastly better than pencil.
Re: need practice sawing dovetails.....?
Re: GREAT simple clamping solution!
paul womack
Dean J in MN
>Bill --
How thick are the pieces you are cutting dovetails in? Looks to be 3/4+? In that case, yes, you really want a bigger saw than the LN. I use my carcass saw for cutting dovetails in 3/4+ size stock, the DT saw is really for 1/2" or under. Case dovetails go much quicker with a bigger saw, and the are easier to sharpen to boot!
-Dean
MikeW
>Hey Bill,
I do something similar for clamping wider boards for joinery. I use a wooden hand clamp on the board which rests on the bench top and another to clamp the clamp to the bench top. The other side, like in your picture, goes into the bench's face vise.
Haven't tried something like you mention for judging the back shoulder line. But hey, always open to other ideas. I'll give it a try for the fun of it!
Take care, Mike
paul womack
Ah - quite similar to my favourite solution when mortising: but bought forward right to the front bench edge.
Duly noted.
BugBear
MikeW
>Precisely so, BB.
I do the same most of the time doing mortises as well. I do still clamp them at the front edge of my bench simply because I am no longer flexible enough to reach over that far .
And I clamp up at least two legs or whatever is receiving the mortises side-by-side and do them together. So both front legs together, etc. That way I can usually line up the mortises equally and therefore the apron with tenons on each end will also layout equally. They get clamped together at the marking stage so the mortise ends line up.
Take care, Mike
2 for 1 marking& chopping a good idea
Bill Tindall, E.TN
A simple dovetail vise ...
>A simple - and cheap! - dovetail vise may be made from two bolts and metal thread inserts. Add a couple of spinners from scrap. Remove the vise when not needed. All that is visible will be the two thread inserts in the bench apron.
When needing to transfer the marks from tails to pins on long boards, I clamp the pin board in the end vise and balance the tail board on a board clamped upright in the dovetail vise.
A corner clamp is used to hold the two together (BB will love this one!)
Great idea, Derek
"RJ" Whelan
>Bill ... I used to have the same problem (re: sawing to the back line).
Many years ago I was in a friend's shop (one of the most skilled cabinet makers I've ever known) and he was sawing dovetails - he had a mirror set up behind the work and it seemed like such a simple aid I gave it a try. I've been using a mirror for over 20 years and probably could saw a DT without it now (still using the original mirror - haven't broken it yet).
RJ
Great minds think alike!
Scott Burr in Ben Lomond, CA
>This is how I clamp large boards too.
Moses Yoder
Re: no more practice, thank you
Moses Yoder
>I just got done with 9 soft maple drawer boxes. Tired of practicing!
You don't want to break the mirror...
Paul M.
>... or you'll have seven years of bad dovetails. ;-)
Re: You don't want to break the mirror...
Dan Donaldson
>Gee, when I think of all the mirrors that I have broken....... ;-)
>Hi RJ
I know that a number of people use mirrors to track the saw cut. I do not bother. I do make sure that I have the outside of the board facing me as I saw. This way I can ensure that the saw does not cut below the line where it will be seen. Does it matter if it goes a mm over the line on the inside where it will not be seen?
muscle memory
Andrew F in Australia
>Hi All,
Just further to Derek's comment, I have the baseline of the cut facing towards me, and just cut until the saw hits it. Once you get the feeling of the saw and know where it's horizontal, you're there.
I haven't taught a workshop class in three years, and haven't done much dovetail work, so the muscle memory's a bit sloppy now. The saw could be out of horizontal by about a skinny 1/16th or so over 3/4" (1mm in 20) This is bad enough to cause problems in show work, but, as Derek said, if it's utility work, it's still OK
The speed in your work comes from the muscle memory, knowing where the saw's horizontal and plumb. To cut dovetails (4 pins or so) in a 3/4" board, I used to spend no more than one to one-and-a-half minutes in total on the saw, and about another five minutes on the chisel, tops. It'd be a bit longer now.
Cheers,
Andrew
typo: not much dovetail work RECENTLY
