Thinning Minwax antique oil.
Scott Burr in Ben Lomond, CA
>My can of Minwax BLO is getting low and thick. What's the best thing to thin it down a bit to get it back to the original consistency?
Thanks!
Re: Thinning Minwax antique oil.
Dan Donaldson
>You ca thin BLO with naptha, but if it is getting thick, it might be at the end of its life. Unless you have a ton of it, I would get rid of it and buy new. Not worth the risk.
Hi Dan, Does it have a shelf life?
>Does it actually get old? I've had the can for maybe a year. I was figuring it was just evaporating from being opened during use.
Re: Hi Dan, Does it have a shelf life?
Dan Donaldson
>Not sure, but it doesn't cure by evaporation. Exposure to oxygen is what does it (that is why oily rags are so dangerous, the reaction is exothermic). If it is getting thick in the can, it is probably starting to cure. I don't believe that thinning will help if that is the case. If it were me, I would not use it on anything that I cared about. The cost/benefit ratio would not be there for me.
Ahhhh I see. Thanks Dan! New can time for me.
