ADVERTISE HERE - FREE TRIAL
Tote making and a Veritas carver's vice
Dominic Greco in Richboro PA
>Hi gang,
I took a break from my hand tool cabinet project in order refurbish a Bedrock 605 that I found at a flea market. The tote and knob were in somewhat sorry shape. And rather than repair them, I decided to make new ones. And rather than make just one set, I decided to make two out of bubinga and one out of cherry.
A while back Clint Jones (Aka: Leonard Bailey) posted a very simple method for making totes on WoodNet. When he posted it, I immediately converted it to a MS Word document and printed out a color copy. It's such a simple process that I figured even I could do it!
I also used some tips gleaned from other posts here and there. One tip was to wrap a piece of wooden dowel in sand paper and use that like a "fine" rasp. That worked wonders!
The other was to use a piece of all thread and some hex nuts as a holder for the tote. I was using my machinist's vice to hold that all thread. But after a while I found I wasn't getting the work piece positioned as well as I'd like.
It was then that I remembered that I now owned a Veritas Carver's Vice. So I took the time and made a plywood stand/holder for it. And once I attached my all thread "tote carving post" to the pedestal, it was an almost magical experience. I was able to move that work piece around and get every angle.
Photobucket
Photobucket
My other great "discovery" while making these totes was that a 2" dia velcro packed sanding pad held in a drill press works just as well at sanding totes as it does bowls. I was sanding "shoe shine fashioned" with strips of cloth backed sandpaper. But that was slow going. The drill press (on slow speed) made short work of the sanding. Here are some photos of the almost completed tote. I still need to sand a bit more (on the base). But it's nearly completed.
Photobucket
Turning the knobs should be a piece of cake. An old pen mandrel will work perfectly for this applications. I'll probably end up making a set of bushings so that I can automate the process more. I have a lot of planes that would look cool(er) with new totes and knobs!
See ya around,
Dominic
Re: Tote making and a Veritas carver's vice
Ummm Dom...
Scott Burr in Ben Lomond, CA
>"It was then that I remembered that I now owned a Veritas Carver's Vice"
I guess you gave up carving decoys and yard Nome's eh?
Say, Could you send me the word file you saved from Woodnet?
I'd love to read it.
Nice looking totes BTW let's see them when their done too...Please!
You get that 46 put back together and working?
Re: Hand Saw Set?
paul womack
>If you put a narrow wedge "angle conpensator" under the tote on the holding screw, it'll sit even more securely.
BugBear
Re: Ummm Dom...
>Scott,
As you know, I used to do wood turning a lot more before I found hand tools. I got that Veritas Carver's Vice at the end of last year for helping Lee Valley out on the design and testing of an accessory to go with it. The accessory is a post that fits on the carvers vise, in place of the main pedestal. One end is threaded to match your lathe's spindle. You can then screw a chuck, or faceplate right onto the post and it will be held in the carver's vice. It's a perfect application for woodturners who want to have their work held while carving or using pyrography (wood burning).
And I promise to post photos of the totes whn they're done.
Later,
Dominic
Re: Hand Saw Set?
>You know, that's not a bad idea. I have a wedge that was cut from the tote. It even has the hole in the right spot!
Thanks for the idea!
Dominic
Link to original article *LINK*
>Scott,
Here is a link to Clint's "article".
BTW, the No46 is second in line after the 605 I'm restoring.
Clint Jone's on Tote making
I'm a little slow this morning...
Victor Parisian
>What are you talking about. Picture/diagram might help.
Victor - Left the a/c off all week end at the office. Ugh.
Victor Parisian
>Nice job there Dom. I really like the idea of the carvers vise and how you have it mounted makes good sense.
Victor - In Hot and Humid Houston
Re: Hand Saw Set?
paul womack
You'd want to reduce the width (of the wedge) to provide all-round access.
Otherwise - as you say - ready made.
BugBear
Thanks Dom!
