We value your privacy.
>I have a Made in Japan tool for flattening water stones that is sort of like a cinder block with slots cut in it. Now it is so smooth it won't flatten anything anymore. I tried washing it with water, Comet, more water and nothing worked. Any ideas?
>How about using carbide powder on it? I have a similar thing, except it is metal and I use the carbide grains on it. You can get the stuff from lapidary suppliers by the pound, which is a lot cheaper than buying it in the little bottles sold for flattening plates.
>Raw guess but I would suggest either getting one of those multi point stone sculpture tools and re-treading the tire, or possibly doing something like running it over a tile saw enough that you get some texture back without affecting the overall flatness. In fact lacking sophisticated tools one might make some headway with a batten clamped to the stone and a 4" disc grinder with a cut-off blade or diamond blade, or same rig with a diamond hacksaw blade.
>Just use some 80 grit wet dry paper and flatten the flattening stone. Only takes a minute and it will be good as new you've just polished it smooth over time.
>Throw the flattening stone away - they are rarely flat. Why flatten the flattening stone when you can flatten the waterstone directly? The cheap option to flatten waterstones is wet n' dry (180 grit for the finer stones) stuck down with water-spray on a piece of float glass or a planer(UK)/jointer(US) table. Unfortunately, the paper only lasts for one or two flatennings. The expensive but stay-flat option is a 10" x 4" DMT Extra Coarse Diamond Plate. However, if you want to put a controlled curve on your plane blades straight off the waterstone, then the Odate Diamond Dressing Plate with a +.025" convex profile puts a consistent concave curve into the waterstone - and no flattening required.
